tomssupra Posted May 7, 2006 Share Posted May 7, 2006 Hi, I've just got the Do-Luck front Bump in from Japan through Sumo, before I start fitting it does anyone know if any work has to be done to get it to fit properly i.e. sanding, drilling etc - or is that only non-genuine ones? Thanks, Tom Link to comment Share on other sites More sharing options...
hodge Posted May 7, 2006 Share Posted May 7, 2006 I would imagine if its a genuine bumper it should replace the standard 1. but theres only 1 way yo find out mate. The front bumper isnt a big jub to remove anyway you could have them swapped in a couple of hours and then change them back for the du-luck to be painted. Link to comment Share on other sites More sharing options...
jazz1 Posted May 7, 2006 Share Posted May 7, 2006 if its original no probems Link to comment Share on other sites More sharing options...
RobSheffield Posted May 7, 2006 Share Posted May 7, 2006 you will likely need to remove the ally bumper bar, and its not gonna fit like stock, even if its genuiine Link to comment Share on other sites More sharing options...
