bromy Posted April 7, 2006 Share Posted April 7, 2006 Just a quickie guys, are the rear shocks the same across the whole supra range i.e tt/na/uk/jspec Link to comment Share on other sites More sharing options...
Ian W Posted April 7, 2006 Share Posted April 7, 2006 different options were available but i believe they're all interchangable afaik. Link to comment Share on other sites More sharing options...
Nic Posted April 7, 2006 Share Posted April 7, 2006 different options were available but i believe they're all interchangable afaik. Different part numbers for the different models and years (different damper/spring rates are used on NA and TT's J-spec and UK-spec), but as said the dampers and springs are interchangable. Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 7, 2006 Share Posted April 7, 2006 They are all different, they are valved differently inside, but you can bolt any on to any other MKIV, it's just they won't match the springs or the weight of the car, which is bad. Link to comment Share on other sites More sharing options...
