I've ditched the SSQV
Bob
Well, the novelty wore off fairly quickly (about 20 minutes actually). But the most deciding factor was the lag I encountered at kickdown today when giving it some beans off the slip road :(
So the bloody thing is sat all lonely-like in my garage, with the freshly cleaned stock BOV nestled in place. Peace perfect peace! :D I may keep hold of it for plans to go single in the (distant) future, but I think even then I'd want to go recirc.
Maybe you didn't have it set up right. They shouldn't give any more lag and do need adjusting.
Really? How on earth do you adjust it?
Though tbh, I'm glad to have got rid of the noise too. It's all fine and dandy when you're giving it some, but the dump valve going off at 20-30mph really is kind of embarassing!
All pipes are / were definitely secured. Not sure baout the spring rate; I bought it 2nd hand and just bolted it straight on without thinking about it.
I just put the lag down to it being at atmospheric BOV rather than a recirc :shrug:
if its second hand the spring rate has been altered, its prop leaking boost (opening) as you start getting on positive boost which is why you are getting a lag
  • 2 weeks later...
As said already a BOV on a J-spec should have no effect on lag/boost what so ever.
I have a couple of brand new HKS SSQV blow off valves on special offer at the moment if anyone is wanting one, see details in Import Pimp section [thread=64952]HERE[/thread]
