_Rob_ Posted March 17, 2006 Share Posted March 17, 2006 hey guys... had a bit of a misshap last nte and need a part, but not sure what its called... anyone know? its the tie bar with the socket wrench on in the pics... its located nearside rear, under the damper / hub assembly. seems to have a ball joint on the end of the hub. cheers. Link to comment Share on other sites More sharing options...
Homer Posted March 17, 2006 Share Posted March 17, 2006 Which bit do you need? the bar or the nut/bolt holding it on? Link to comment Share on other sites More sharing options...
Homer Posted March 17, 2006 Share Posted March 17, 2006 pic below from epc if it helps. This is the pre-REAS Jap version, but i have no reason to beleive the UK has a different setup. The LH and RH seem to have the same part number: 46710-14110 ARM ASSY, REAR SUSPENSION, NO1 LH Link to comment Share on other sites More sharing options...
_Rob_ Posted March 17, 2006 Author Share Posted March 17, 2006 spot on, cheers bud! nipped down to toyota to order the part. ive ordered a new set of bolts etc for it too. clipped a kerb last night and sheared the ball joint. Link to comment Share on other sites More sharing options...
Homer Posted March 17, 2006 Share Posted March 17, 2006 Ouch, I've been there! Out of interest, how much did they charge you for it? Link to comment Share on other sites More sharing options...
LeeT Posted March 17, 2006 Share Posted March 17, 2006 spot on, cheers bud! nipped down to toyota to order the part. ive ordered a new set of bolts etc for it too. clipped a kerb last night and sheared the ball joint. thats a shame ive got some spares of these with bolts in the garage. i'd have a good look at the hub too if i were you. if you've sheared the balljoint theres a good chance you have damaged the hub as well. you will need the wheel alignment set back up again too Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 17, 2006 Share Posted March 17, 2006 Replace the rear upright, too. It's almost certainly bent or weakened. i wouldn't want to run the car unless that was changed, too. Link to comment Share on other sites More sharing options...
_Rob_ Posted March 18, 2006 Author Share Posted March 18, 2006 thats a shame ive got some spares of these with bolts in the garage. bugger... was 97 quid from Mr T. not too bad! yeah im gonna have a good look at the whole assembly tomorrow. ill check the rear upright too, cheers Chris. ive been reccomended to strip most of the suspension assembly out to inspect and compare to the offside assembly. shes off the road till may now anyway so will have ample time to get her sorted and alligned. Link to comment Share on other sites More sharing options...
LeeT Posted March 18, 2006 Share Posted March 18, 2006 if you need any of the other bits let me know Link to comment Share on other sites More sharing options...
_Rob_ Posted March 18, 2006 Author Share Posted March 18, 2006 Cheers Leett, will do...! Link to comment Share on other sites More sharing options...
