I.A.C location?
movistar
Hi new to all this as this is my first thead,can any one tell me where my i.a.c valve is located as i want to clean it out......... in hoping this will cure my too high idle problem when cold(about 1600rpm at the mo but drops down to normal....eventually!!)
many thanks.
Mine idles high, typically 900-1000rpm, sometimes it drops a little lower but NEVER to 600rpm.
When sat idling it cycles from 900 up to 1100 for around 10 or 11 secs then back to 900 for about 40 secs then up again. Quite annoying!
Any ideas people or anyone have anything similar?
Guest Terry S
They also seem to rise/drop dependant on the quality of fuel. If I ran race fuel, or Toluene in mine the idle RPM would drop below 500.
Isn`t this controlled to some degree by the ECU?
When i start my car it shoots up to about 1700 then about 3 - 6 seconds later settles at 700 - 800 rpm.
:thumbs:
Mine:-
If STONE cold (early morn') - ~1400/1500 and almost immediately
drops to ~1300.
Then, slowly drops as temp rises to the 'bottom' white line on Temp
till ~ 1000.
then as it warms to the '1/2' way mark it does the final settle to
~800.
I had my idle rise to ~1200 - no matter WHAT temp - a month
or two ago - that WAS the IAC/ICV.. it had a small piece of
'gasket' caught under it's 'seat' so COULDN'T shut to the HOT
position ! ! !
A/C makes it rise/fall by ~200 revs - ie. 800-1000-800-1000
(or ~200 variation if still on high Idle)
I understand that air con will result in rise/fall of rpm but what if rpm rises and falls in the pattern i described above regardless of aircon on or off?
I always run optimax from same place so for me it's not fuel related.
Cold start 1200-1300 ish then drops very soon to 900ish. Then begins cycling upto 1100 is and back and forth.
Any ideas, or areas i can investigate?
NO, you're right, shouldn't really vary up/down once warmed
properly ! ! !
Not by much anyhow.
(I suppose mine alters by ~ +/- 50 ? ? ie 750-850 -ish ? ?
but, even then, only slowly if REALLY thrashed or cruised or sumthin' ?)
Minor air leak ?? Is it sort of 'Hunting' ie High-Low-High in ~1/2-1
second cycles ? ? ? ?
FatS.
No it's odd. It will idle at say 850rpm for about 40secs then rise to 1100rpm for 10secs then drop back down again. Then cycles as described.
I'm sure it's not a leak as it makes a clunking noise when it rises (as if some mechanism stepped in to raise it on purpose). It follows a regular pattern too.
mmmmmmm........ the 'CLUNK' sounds exactly like the
Air Con clutch locking in ! ! ! ! !
you SURE your A/C isn't on when it happens ! ! ! :conf:
(nb. you know it comes on regardless if you switch the SCREEN
position on ? - NOT being PATRONISING ! ! !:( )
FatS.
FatS.
Steve, not on my UK motor it don't...
What do you mean "not on your UK.."
AFAIK, ALL (UK/JAP) cycle up/down with A/C... it's SUPPOSED to
to compensate for the drag on the engine......
[ and, ALL will make a fair 'clunk' that's just what A/C is like :conf: ]
and the A/C comes on when you select the SCREEN (only) so as to
automatically clear the screen (the OTHER use for A/C).
Yeah, it does surge when the a/c compressor clutch engages and you are right about the extra strain, but when I push windscreen it does speed up the blower and change to auto, but it doesn't start the a/c up, on mine anyway.
Nice avatar BTW!:D
