bilstein odd ride hight
lambertpig
hi, just been to pick up supra had bilstein sport shocks fitted already running eibach springs 19" wheels.problems the 2 rears are a odd hight about 1 inch diffence clearance between arches. the hight on one side seems as was before and higher on the other from before. both fronts seem to have drooped a little and now just catches on wheels ,removing the middle inner arch nut seems to have cured this after some spirited testing roundabouts.the ride is harder/bumping/banging than before but handling well im not sure its any better than the uk shocks on before.any ideas about the rears.the garage have kept the car and are refitting rears tommorow they have said that the springs are loose on the shocks but i have seen threads regarding this before HELP PLEASE
still got stock shocks they were on the car this morning sitting perfectly just a bit bouncy i was really hoping the handling would now be perfect but its not right.im hoping they must have not seated one properly at the rear cant see how though and they are pretty reliable lads
Any evidence of one of the Bilstein dampers leaking fluid?
They can have no fluid in them at all and the ride height won't change.
Well, it will, by a fraction, if you are being pedantic, as the gas charge gives them a TINY bit of spring rate of their own, so if the gas is lost the ride height may change, but I'd bet it couldn't even be measured with a vernier ;)
:yeahthat: :whistle:
yep further to my last post one of the new bilsteins is leaking ,this is the side that is low on the front and the opposite of the one high at the rear looks like this could be my prob it really crashes and bangs otver bumps on this side. thanks everybody for all the tech advice bilstein are sending a replacement ,if this dont work then im really screwed
Sorry, I didn't see this post when I replied to your other thread.
I had the "loose" spring thing too, when I had the Bilstein and Eibach combination. My car was very low at the front, like yours too. And the Bilstein and stock spring combination didn't need a spring compressor to assemble either, although not as loose.
See my previous posts:
http://www.mkivsupra.net/vbb/showthread.php?t=54765&highlight=Bilstein
http://www.mkivsupra.net/vbb/showthread.php?t=42043
I've never really got to the bottom of this.
The Bilsteins are aftermarket (ie. not marked with Toyota) and have the part no.s:
  • F4-B46-1792-HO -Front
  • F4-B46-1793-HO -Rear
The Eibach Spring part no.s are (although I'm back on stock now):
  • 8222.001
  • 8222.002
Reading your post, it sounds similar to my experience and I am still a little suspicious that the after market Bilsteins are different to Toyota Bilsteins.. or maybe that there are different versions of the after market ones? From the part numbers I've no idea if my shocks are the right ones or not. I've attached pics of mine and the Toyota marked ones, just for reference (ignore the red-circled spring seat this time... that was the other problem :) ).
All that said my car seems to drive ok with the stock springs and Bilsteins. The car is now pretty much level. But I guess it’s possible that it’s still not at it’s best!
Anyway hope you get yours sorted!
