Lots of aftermarket goodies.
michel lane
 Share
Barely used Veilside TI exhaust with silancer excellent condition - to big to ship collection only please , unless you want to pay £35 for shipping .
You cant buy this anymore in the UK , 3 months shipping from japan , iam changing to a full 4inch system , so my mid pipe will not fit it : fits all standard mid pipes 2 bolt connection , i have to use a V BAND connection with mine £700. cost me £850
Used UK fuel pump , done around 45000 miles. - £20
Set of 355*30*18 parelli PZERO tyres new , bought them but they dont fit my arches £500 for the pair
White UK spoiler excellent condition - £80
Meth injection kit - This includes the meth frendly pump , its not the small one ither , it has lines and relays , it comes with 4 injectors aswell. The lines are all 160 psi lines meth lines , not the cheap type . Comes with connectors . Every individual has different setups on these kits so there is no instructions with them. I was going to use the Supraforum suggestions , there are about 4 methods on there . You would need a pressure controller if you want it to come in at a certain PSI. I was going to use it wth my AEM, my plans have changed . Who needs race fuel when you can buy meths so much cheaper. £200
ERL water injection - This is the race version with race pump, small computer and relays- Its still on the car , i have lost the instructions but you can get them from ERL website . I has everything with it , you may need to buy some new hoses because depending on were you want to mount it . You can by additional spray nozzles from ERL if you require larger ones. Best way to keep your engine from blowing up running high boost . I have a new version with dual pumps now which the AEM controls. I paid £500 for this kit in june asking £250
All items are Plus postage and packaging .
The standard engine will run a T88 running at 1.4 with no issues , you need to purchase the various bits :
fuel system
manifold
dp/mp
fuel controller
wastegate
all depends on your goals . it makes a pretty good budget system if you are not in a hurry to get full boost from it . I used it and it was great , but different people have different views on these turbo's, some say laggy , some say old hat ... i have my views , they are reliable and lag is dependable on you gear change and your right foot . 4600rpm and full boost, thats not laggy, but compared to T61 3900rpm but dies out after 6000 rpm, this thing just pulls
fuel system
manifold
dp/mp
fuel controller
all depends on your goals . it makes a pretty good budget system if you are not in a hurry to get full boost from it . I used it it was great , but different people have different views on these turbo's, some say laggy , some say old hat ... i have my opions , they are reliable and lag is dependable on you gear change and right foot . 4600rpm and full boost, thats not laggy
dp / mp ???
because its a v band , i was running a 4inch dp/mp . not that hard to source now , you could use the 3 inch vband from ebay which i used first and the midpipe was a HKS one , but i wanted a 4inch version. If you had the 4 bolt version then it would be hard to find . This turbo actually sits on a ebay manifold without any issues as we tried it with one , but it was one of the early manifolds without strenghteners on them. We used the manfold for a T62 turbo instead using the 3 inch dp.
what ecu did you finally use ??? and how much rwhp and what boost?
I decided on the M800 Motec but have not yet had it on the rollers properly to get a power figure. I currently run at 1.4 bar but when the T67 was on I ran 1.9 - until it went pop! :whistle:
There was one 6 months ago for £650 not £550 as i recall . That was then this is now ... trying getting a hold of one for less then £850 delivered will be like rock horse shit !!!!.... anycase its called, if you want it then you got to pay the price else, leave it alone . Willing to swap it for a boost logic 4 inch out there if anyon has one .
 Share
