typy Posted December 30, 2005 Share Posted December 30, 2005 Quick question!!!! Wot is the Supra geared 2?? Like wot does each limit 2 i mph?? Cheers Link to comment Share on other sites More sharing options...
colsoop Posted December 30, 2005 Share Posted December 30, 2005 Quick question!!!! Wot is the Supra geared 2?? Like wot does each limit 2 i mph?? Cheers Are you asking what mph you can do in each gear, im not quite sure so: 1st 40 mph 2nd 65 mph 3rd 95mph 4th 125 mph 5th 150 mph 6th ?? All the above are from a non vvti car and read from the speedo which is known to be a bit optimistic with its readings. Link to comment Share on other sites More sharing options...
carl0s Posted December 30, 2005 Share Posted December 30, 2005 Quick question!!!! Wot is the Supra geared 2?? Like wot does each limit 2 i mph?? Cheers It's on here already, posted by Alex and re-posted (or linked) about 2 weeks ago. Link to comment Share on other sites More sharing options...
carl0s Posted December 30, 2005 Share Posted December 30, 2005 http://www.mkivsupra.net/vbb/showthread.php?t=29830&highlight=ratio Well I was a bit bored so using the Quaife Gearbox calc tool I've put together a list of all the main combo's of gearboxes and the speeds attainable by them. Mainly of interest to me was the major differences between the V160 and V161 manual gearboxes...the latter being much better gear (yay) for dragging with uprated power, as you're not in danger of having to switch up to 5th unless you're running silly power...but check out the Auto with the UK Manual Diff - lol how fast! Gearbox:- 2JZ-GTE VVTI V161 6-Spd Tyre:- Michelin all patterns 235/45 x 17 ------------------------------------------------------------------------------------------- Top Gear gives 27.348 MPH/1000 RPM and a top speed of 191.438 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 1097 RPM 40 MPH = 1463 RPM 50 MPH = 1828 RPM 60 MPH = 2194 RPM 70 MPH = 2560 RPM 80 MPH = 2925 RPM 90 MPH = 3291 RPM 100 MPH = 3657 RPM Top Speed in 1 gear = 42.050 MPH And changes into 2 gear at 4222 RPM dropping 2778 RPM Top Speed in 2 gear = 69.722 MPH And changes into 3 gear at 4803 RPM dropping 2197 RPM Top Speed in 3 gear = 101.620 MPH And changes into 4 gear at 5474 RPM dropping 1526 RPM Top Speed in 4 gear = 129.955 MPH And changes into 5 gear at 5809 RPM dropping 1191 RPM Top Speed in 5 gear = 156.596 MPH And changes into 6 gear at 5726 RPM dropping 1274 RPM Top Speed in 6 gear = 191.438 MPH ****************************************************************************************** Gearbox:- 2JZ-GTE V160 6-Spd Tyre:- Michelin all patterns 235/45 x 17 ------------------------------------------------------------------------------------------- Top Gear gives 28.210 MPH/1000 RPM and a top speed of 197.473 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 1063 RPM 40 MPH = 1418 RPM 50 MPH = 1772 RPM 60 MPH = 2127 RPM 70 MPH = 2481 RPM 80 MPH = 2836 RPM 90 MPH = 3190 RPM 100 MPH = 3545 RPM Top Speed in 1 gear = 40.919 MPH And changes into 2 gear at 4317 RPM dropping 2683 RPM Top Speed in 2 gear = 66.354 MPH And changes into 3 gear at 4998 RPM dropping 2002 RPM Top Speed in 3 gear = 92.935 MPH And changes into 4 gear at 5450 RPM dropping 1550 RPM Top Speed in 4 gear = 119.357 MPH And changes into 5 gear at 5335 RPM dropping 1665 RPM Top Speed in 5 gear = 156.596 MPH And changes into 6 gear at 5551 RPM dropping 1449 RPM Top Speed in 6 gear = 197.473 MPH ****************************************************************************************** Gearbox:- 2JZ-GE (NA) W58 5-Spd Tyre:- Michelin all patterns 235/45 x 17 ------------------------------------------------------------------------------------------- Top Gear gives 22.854 MPH/1000 RPM and a top speed of 159.976 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 1313 RPM 40 MPH = 1750 RPM 50 MPH = 2188 RPM 60 MPH = 2625 RPM 70 MPH = 3063 RPM 80 MPH = 3501 RPM 90 MPH = 3938 RPM 100 MPH = 4376 RPM Top Speed in 1 gear = 38.131 MPH And changes into 2 gear at 4036 RPM dropping 2964 RPM Top Speed in 2 gear = 66.136 MPH And changes into 3 gear at 4712 RPM dropping 2288 RPM Top Speed in 3 gear = 98.244 MPH And changes into 4 gear at 5490 RPM dropping 1510 RPM Top Speed in 4 gear = 125.261 MPH And changes into 5 gear at 5481 RPM dropping 1519 RPM Top Speed in 5 gear = 159.976 MPH ****************************************************************************************** Gearbox:- 2JZ-GTE AUTO 4-spd Tyre:- Michelin all patterns 235/45 x 17 ------------------------------------------------------------------------------------------- Top Gear gives 27.497 MPH/1000 RPM and a top speed of 192.478 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 1091 RPM 40 MPH = 1455 RPM 50 MPH = 1818 RPM 60 MPH = 2182 RPM 70 MPH = 2546 RPM 80 MPH = 2909 RPM 90 MPH = 3273 RPM 100 MPH = 3637 RPM Top Speed in 1 gear = 48.394 MPH And changes into 2 gear at 3822 RPM dropping 3178 RPM Top Speed in 2 gear = 88.633 MPH And changes into 3 gear at 4572 RPM dropping 2428 RPM Top Speed in 3 gear = 135.697 MPH And changes into 4 gear at 4935 RPM dropping 2065 RPM Top Speed in 4 gear = 192.478 MPH ****************************************************************************************** Gearbox:- 2JZ-GE (NA) AUTO 4-Spd Tyre:- Michelin all patterns 235/45 x 17 ------------------------------------------------------------------------------------------- Top Gear gives 25.382 MPH/1000 RPM and a top speed of 177.676 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 1182 RPM 40 MPH = 1576 RPM 50 MPH = 1970 RPM 60 MPH = 2364 RPM 70 MPH = 2758 RPM 80 MPH = 3152 RPM 90 MPH = 3546 RPM 100 MPH = 3940 RPM Top Speed in 1 gear = 44.672 MPH And changes into 2 gear at 3822 RPM dropping 3178 RPM Top Speed in 2 gear = 81.817 MPH And changes into 3 gear at 4572 RPM dropping 2428 RPM Top Speed in 3 gear = 125.261 MPH And changes into 4 gear at 4935 RPM dropping 2065 RPM Top Speed in 4 gear = 177.676 MPH ****************************************************************************************** Gearbox:- 2JZ-GTE VVTI V161 6-Spd w/UK DIFF Tyre:- Michelin all patterns 235/45 x 17 ------------------------------------------------------------------------------------------- Top Gear gives 28.509 MPH/1000 RPM and a top speed of 199.564 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 1052 RPM 40 MPH = 1403 RPM 50 MPH = 1754 RPM 60 MPH = 2105 RPM 70 MPH = 2455 RPM 80 MPH = 2806 RPM 90 MPH = 3157 RPM 100 MPH = 3508 RPM Top Speed in 1 gear = 43.836 MPH And changes into 2 gear at 4222 RPM dropping 2778 RPM Top Speed in 2 gear = 72.682 MPH And changes into 3 gear at 4803 RPM dropping 2197 RPM Top Speed in 3 gear = 105.934 MPH And changes into 4 gear at 5474 RPM dropping 1526 RPM Top Speed in 4 gear = 135.472 MPH And changes into 5 gear at 5809 RPM dropping 1191 RPM Top Speed in 5 gear = 163.244 MPH And changes into 6 gear at 5726 RPM dropping 1274 RPM Top Speed in 6 gear = 199.564 MPH ****************************************************************************************** Gearbox:- 2JZ-GTE V160 6-Spd w/UK DIFF Tyre:- Michelin all patterns 235/45 x 17 ------------------------------------------------------------------------------------------- Top Gear gives 29.408 MPH/1000 RPM and a top speed of 205.856 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 1020 RPM 40 MPH = 1360 RPM 50 MPH = 1700 RPM 60 MPH = 2040 RPM 70 MPH = 2380 RPM 80 MPH = 2720 RPM 90 MPH = 3060 RPM 100 MPH = 3400 RPM Top Speed in 1 gear = 42.656 MPH And changes into 2 gear at 4317 RPM dropping 2683 RPM Top Speed in 2 gear = 69.171 MPH And changes into 3 gear at 4998 RPM dropping 2002 RPM Top Speed in 3 gear = 96.880 MPH And changes into 4 gear at 5450 RPM dropping 1550 RPM Top Speed in 4 gear = 124.424 MPH And changes into 5 gear at 5335 RPM dropping 1665 RPM Top Speed in 5 gear = 163.244 MPH And changes into 6 gear at 5551 RPM dropping 1449 RPM Top Speed in 6 gear = 205.856 MPH ****************************************************************************************** Gearbox:- 2JZ-GTE AUTO 4-spd w/UK MANUAL DIFF Tyre:- Michelin all patterns 235/45 x 17 ------------------------------------------------------------------------------------------- Top Gear gives 33.079 MPH/1000 RPM and a top speed of 231.551 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 907 RPM 40 MPH = 1209 RPM 50 MPH = 1512 RPM 60 MPH = 1814 RPM 70 MPH = 2116 RPM 80 MPH = 2418 RPM 90 MPH = 2721 RPM 100 MPH = 3023 RPM Top Speed in 1 gear = 58.218 MPH And changes into 2 gear at 3822 RPM dropping 3178 RPM Top Speed in 2 gear = 106.625 MPH And changes into 3 gear at 4572 RPM dropping 2428 RPM Top Speed in 3 gear = 163.244 MPH And changes into 4 gear at 4935 RPM dropping 2065 RPM Top Speed in 4 gear = 231.551 MPH ****************************************************************************************** Gearbox:- 2JZ-GTE AUTO 4-spd w/JAP MANUAL DIFF Tyre:- Michelin all patterns 235/45 x 17 ------------------------------------------------------------------------------------------- Top Gear gives 31.732 MPH/1000 RPM and a top speed of 222.122 MPH at 7000 RPM Engine speeds in top gear:- 30 MPH = 945 RPM 40 MPH = 1261 RPM 50 MPH = 1576 RPM 60 MPH = 1891 RPM 70 MPH = 2206 RPM 80 MPH = 2521 RPM 90 MPH = 2836 RPM 100 MPH = 3151 RPM Top Speed in 1 gear = 55.847 MPH And changes into 2 gear at 3822 RPM dropping 3178 RPM Top Speed in 2 gear = 102.283 MPH And changes into 3 gear at 4572 RPM dropping 2428 RPM Top Speed in 3 gear = 156.596 MPH And changes into 4 gear at 4935 RPM dropping 2065 RPM Top Speed in 4 gear = 222.122 MPH ****************************************************************************************** Link to comment Share on other sites More sharing options...
Branners Posted December 30, 2005 Share Posted December 30, 2005 Quick question!!!! Wot is the Supra geared 2?? Like wot does each limit 2 i mph?? Cheers typy, we dont like txt spk on here, can you please type properly and put coherent sentences in. thanks JB Link to comment Share on other sites More sharing options...
