Getting really concerned now :(
GazzaGSi
 Share
After the mechanic and I had been testing various things under the bonnet we have come to the conclusion the culprit was the Rotar arm! Absolutely burnt to a crisp.
Which would be why the car has had the symptoms it has. When it was runnning roughly the rotar arm must not of been connecting with all the tips in the dizzy cap, And come to think of it when it was running poorly it sounded like the leads were connected incorrectly which I can only assume would be when the rotar wasnt connecting properly. This is the only thing we come across that was bad, all earhting points etc and the battery are fine - so fingers crossed this is the problem. Attached are some pics of the worn rotar.
For those interested I just thought I would let you know that the car has been running fine since the change of the rotar arm. Probably around 5 - 6 hrs driving time and no cut outs :D
Thanks for everyones help and suggestions and if anything untoward happens, I will let you know.
Thanks again,
Gaz
 Share
