Water Pump a bit squeaky
carl0s
My water pump is getting a bit squeaky. Not a lot, but it detracts from the overall sewing-machine smoothness of the engine. Does anyone know if these are expensive?
I'm presuming it's the water pump anyway - it's on the uppermost right of the accessory-belt routing and looks fairly basic.
Water pump is about £140 ish from Toyota
Dude, that's your power steering pump. If they go squeaky it could be bearing failure. Have a look here and see if it looks like the same bit of kit?
-Ian
-Ian
Ah, yes you are right :D
As it happens, it's been sounding fine since then. I had not used the car for about three days due to hangover, and it had been quite a bit frozen. It's been fine since that first journey. I guess I'll see how it goes..
