Suprasteve Posted December 23, 2005 Share Posted December 23, 2005 I got home from about a 10 mile motorway drive yesterday night, i was driving fairly smoothly. The water temp gauge was reading normal (exactly half way) but when i parked up and got out of the car i heard a very loud bubbling noise coming from the radiator. I had a look with a torch but the battery was on its way out so i couldn't see much but i'm sure there was no leaking. I touched the large pipe going from the engine to the rad and it was bloody hot but i assume it would be hot anyways? I drove 10 mins to work this morning and everything was fine. When i get a min i'll check the water levels etc but for now do you think i have any cause for concern ? Link to comment Share on other sites More sharing options...
Guru Posted December 23, 2005 Share Posted December 23, 2005 Water levels are the main thing to check. What is the temp range that the standard gauge says anyways? I presume normal is around 90C I think so bubbling may not be that bad Link to comment Share on other sites More sharing options...
mikeyb10supra Posted December 23, 2005 Share Posted December 23, 2005 nope would'nt worry dude, as long as the temp is constant and your not losing fluid you should be fine....might just be air pockets in the coolant causing the bubbling Link to comment Share on other sites More sharing options...
Suprasteve Posted December 23, 2005 Author Share Posted December 23, 2005 Water levels are the main thing to check. What is the temp range that the standard gauge says anyways? I presume normal is around 90C I think so bubbling may not be that bad yeah i'm thinking about 90C but i'm clueless nope would'nt worry dude, as long as the temp is constant and your not losing fluid you should be fine....might just be air pockets in the coolant causing the bubbling I'll check levels later, probably needs a good flush ? The car seemed fine at the time so not too worried, but nice to have reassurance....cheers guys Link to comment Share on other sites More sharing options...
Dragonball Posted December 23, 2005 Share Posted December 23, 2005 Do a quick 'search' mate - often sign your rad cap may be on it's way out - losing pressure etc... Link to comment Share on other sites More sharing options...
Burna Posted December 23, 2005 Share Posted December 23, 2005 How old is your rad cap? Link to comment Share on other sites More sharing options...
Suprasteve Posted December 23, 2005 Author Share Posted December 23, 2005 Do a quick 'search' mate - often sign your rad cap may be on it's way out - losing pressure etc... hmmm did wonder that.. How old is your rad cap? its the original one i believe 1994. worth getting a trd one off ebay do you think ? Link to comment Share on other sites More sharing options...
mikeyb10supra Posted December 23, 2005 Share Posted December 23, 2005 Stick with the standard one mate.....TRD cap holds more pressure 1.3 bar I believe, and I have heard of people having problems with these?? get on the blower to Steve Manley, I got one from him for £8 all in I think...or may have been £12 Link to comment Share on other sites More sharing options...
Suprasteve Posted December 23, 2005 Author Share Posted December 23, 2005 Stick with the standard one mate.....TRD cap holds more pressure 1.3 bar I believe, and I have heard of people having problems with these?? get on the blower to Steve Manley, I got one from him for £8 all in I think...or may have been £12 sounds better than £26 from ebay, were can i get his number ? Thanks Link to comment Share on other sites More sharing options...
JohnA Posted December 23, 2005 Share Posted December 23, 2005 I, too, would think twice before fitting a 'performance' rad cap on an ageing cooling system. All they do is force the circuit to operate at a higher pressure. Then they wonder why the rad cracked, lol... Link to comment Share on other sites More sharing options...
Suprasteve Posted December 23, 2005 Author Share Posted December 23, 2005 Stick with the standard one mate.....TRD cap holds more pressure 1.3 bar I believe, and I have heard of people having problems with these?? get on the blower to Steve Manley, I got one from him for £8 all in I think...or may have been £12 what a top nice bloke he is. getting it delivered next thursday £11.13. Link to comment Share on other sites More sharing options...
toyotasuprauk Posted December 24, 2005 Share Posted December 24, 2005 I had this same problem, got a new rad cap and it solved the problem. Like others have said the standard toyota cap is best. Link to comment Share on other sites More sharing options...
