Air Charge Temp Gauge - what hose should I plumb into?
hadyn
Thanks for the info guys :yes:
Just make sure that the probe is meant to survive under those conditions (thermal cycles, boost).
Some have been known to snap off and go for a ride --- perhaps eating up valve seats in the process
This is most worrying! Im presuming the kit i've got is meant for turbo'd car applications as it has intstructions that are for applying it to a car and has a ready made T-piece. How likely is the above to happen?:read:
One I've got is from nomadracing and it is specific for charge temps on cossies and the like.
The guy said explicitly NOT to fit it straight in the charge air path, because he knows of several that eventually broke off and got sucked in by the engines. I followed his instructions and fitted it in a T that is dead end (going to a pressure sensor I've got) but it's a crap location.
It doesn't follow the variations of charge temps, rather becomes a glorified engine temp gauge.
  • 2 weeks later...
yeah, but it doesn't follow the temperature changes closely enough.
Once the engine hits operating temps the charge temp will appear to be static, irrespective of boost conditions. It will appear to be affected much more from the radiator fan than boost, which is not true for charge-air temps.
The probe must be in the flow of air, not taken from a Tee.
Fluid Dynamics 101:- "a locked volume of Fluid (air) will not show a thermal change as rapidly as the source"
locked volume meaning a pipe with a tee that is not flowing.
If you teed both sides then you will see much better results as you will have a flow over the probe. Not sure if this is what you are doing.
...If you teed both sides then you will see much better results as you will have a flow over the probe. .
Why would there be flow over the probe?
To have flow we need a pressure difference across the ends of the pipe, and this one won't have much of that, will it?
I guess it's worth trying, it can't be worse than the T
I am still trying to work out the effect of air velocity on temprature. I had a probe just in front of the throttle butterfys, The temp dropped while moving (open throttle) but shot up while stationary.
I have my doubts that the reading is correct as for a simple test I let the probe settle in still air outside the car then drove down the road with it out the window, this too measured a drop.
So hadyn, even if you fit your sensor in the correct place you may just have another gauge with meaningless numbers displayed.
Expensive gauges are normally expensive for a reason.
