ChrisB Posted July 8, 2003 Share Posted July 8, 2003 Anyone help me I was taking my radio out at the weekend to replace it with my kenwood unit, but when ive put it all back toagther the airbag light is staying on the dash, any ideas what ive done?? Cheers for any advice Chris:) Link to comment Share on other sites More sharing options...
Willson Posted July 8, 2003 Share Posted July 8, 2003 I have never done this but.............this should help. http://www.mkiv.com/techarticles/airbag_light/airbag.htm Link to comment Share on other sites More sharing options...
Geezabloke Posted July 8, 2003 Share Posted July 8, 2003 Follow the instructions, I did same last week, however on a UK spec the plud is on the side of the engine not the rear bulkhead. It does work but i found i needed the car running?:flame Dev Link to comment Share on other sites More sharing options...
Gaz Walker Posted July 8, 2003 Share Posted July 8, 2003 Just about everyone falls into that trap, unless you read the how to first Gaz. Link to comment Share on other sites More sharing options...
Geezabloke Posted July 8, 2003 Share Posted July 8, 2003 Hmmmmm WISE WORDS MASTER:D Link to comment Share on other sites More sharing options...
GavinL Posted July 8, 2003 Share Posted July 8, 2003 Originally posted by Gaz Walker Just about everyone falls into that trap, unless you read the how to first Gaz. Only the once Link to comment Share on other sites More sharing options...
Ian C Posted July 8, 2003 Share Posted July 8, 2003 Oho, so it's if you disconnect it while the ignition is on? I thought it was if you put the ignition on with it disconnected, but I can safely say that everything works fine still if you do that -Ian PS my diagnostic connector isn't anywhere near that shown in the picture...? Link to comment Share on other sites More sharing options...
Gaz Walker Posted July 8, 2003 Share Posted July 8, 2003 Originally posted by Ian C Oho, so it's if you disconnect it while the ignition is on? I thought it was if you put the ignition on with it disconnected, but I can safely say that everything works fine still if you do that No, its the other way round, it will go on if you put the ign on when its disconnected... You car must be backward Ian Gaz. Link to comment Share on other sites More sharing options...
ChrisB Posted July 9, 2003 Author Share Posted July 9, 2003 cheers for the reply's everyone, ill go have a play now:cool: Link to comment Share on other sites More sharing options...
Ian C Posted July 9, 2003 Share Posted July 9, 2003 Originally posted by Gaz Walker No, its the other way round, it will go on if you put the ign on when its disconnected... You car must be backward Ian Gaz. I had the dash off while putting the EGT gauge in and I started the car with the top and left hand side dash panels off, everything disconnected. Car started and ran fine, now it's back together I have no flashing airbag light... I've done this several times now, and never have had this problem. COuld it be a facelift thang? -Ian Link to comment Share on other sites More sharing options...
ChrisB Posted July 14, 2003 Author Share Posted July 14, 2003 it still hasnt worked the light goes out whenever i put the ab wire to the negative but as soon as i take it off the light comes back on the dash any ideas or am i just being a bit thick Link to comment Share on other sites More sharing options...
Guest Martin F Posted July 14, 2003 Share Posted July 14, 2003 Have you read the article properly ? Particularly this bit ......... With the ignition key turned to the ON position alternate the two wires to the negative terminal of the battery. They need to be done in a consistent rhythm, about one second apart. TC,AB,TC,AB,TC,AB... This needs to be done several times. If you can't get it to work, try adjusting the speed. Link to comment Share on other sites More sharing options...
ChrisB Posted July 14, 2003 Author Share Posted July 14, 2003 yeah ill have to give it another go though and try a bit more patients this time, just wondered with the light going out straight away and then coming back on, not to worry ill give it another go Link to comment Share on other sites More sharing options...
Dragonball Posted July 14, 2003 Share Posted July 14, 2003 Chris - wish I had a quid for every time this had happened! Secret is to get someone to sit there while you alternate every second and shout when goes off permanent! It's easier with two! (Oo-er missus!) Link to comment Share on other sites More sharing options...
ChrisB Posted July 14, 2003 Author Share Posted July 14, 2003 i think i may see the problem the person helping was not helping time to find another little helper lol ill give it a go tonight Link to comment Share on other sites More sharing options...
