supra-alex Posted November 28, 2005 Share Posted November 28, 2005 Hi alex Thank you for your enquiry. We can dispatch the Parts for your toyota supra sz-r 1996 N 2 door coupe within 24 hours. I’m sure you’ll be pleased with price of the parts you have requested and become a new customer to Car Parts Direct. With over 25,000 mail order customers throughout the UK your order is safe with us – we’ve been established for over 20 years! Assuming 2 piston calipers and 296mm diameter discs then parts are available as follows: Front standard discs @ £65.00 each*; Front pads @ £44.95*; *Standard discs and pads are VAT FREE when purchased together. If looking to upgrade the discs then Rossini drilled and grooved replacements are available at £184.50 a pair. Carriage is normally £5.00 for any size of order but, if your order total is more than £50.00 (excluding carriage), and you order online before midnight tonight there is no carriage charge whatsoever to pay - your delivery will be absolutely Free! Prices are subject to VAT. his he correct in saying that my discs would be this size and have 2 pistons and is it a bit dodgy ordering a make like this ? Link to comment Share on other sites More sharing options...
supra-alex Posted November 28, 2005 Author Share Posted November 28, 2005 looking at previous threads i think the best thing where money is an object is to get stock discs and stock pads sims toyota quoted me: £95 for the set of pads and around £165 for front discs. that will have to do. Link to comment Share on other sites More sharing options...
Nic Posted November 28, 2005 Share Posted November 28, 2005 He is quoting a price for the smaller spec discs and pads. Drilled discs, especially cheap ones like these are prone to cracking, get a set of stock discs. What brakes do you have on your car? There are 2 options for the Supra: Smaller spec = 2pot caliper front and 1 pot caliper rear. Larger Spec = 4 pot caliper front 2 pot caliper rear. Link to comment Share on other sites More sharing options...
supra-alex Posted November 28, 2005 Author Share Posted November 28, 2005 He is quoting a price for the smaller spec discs and pads. Drilled discs, especially cheap ones like these are prone to cracking, get a set of stock discs. What brakes do you have on your car? There are 2 options for the Supra: Smaller spec = 2pot caliper front and 1 pot caliper rear. Larger Spec = 4 pot caliper front 2 pot caliper rear. they'll be the stock ones still ? Link to comment Share on other sites More sharing options...
RobSheffield Posted November 28, 2005 Share Posted November 28, 2005 if you have smaller ones, use Nic to source parts for the Larger brake conversion! then speak to Chris Wislon for some of his wonder pads! Link to comment Share on other sites More sharing options...
supra-alex Posted November 29, 2005 Author Share Posted November 29, 2005 He is quoting a price for the smaller spec discs and pads. Drilled discs, especially cheap ones like these are prone to cracking, get a set of stock discs. What brakes do you have on your car? There are 2 options for the Supra: Smaller spec = 2pot caliper front and 1 pot caliper rear. Larger Spec = 4 pot caliper front 2 pot caliper rear. what price can you do for me then for a 96 facelift sz-r then assuming i have i the small discs which i must have !! Link to comment Share on other sites More sharing options...
Nic Posted November 29, 2005 Share Posted November 29, 2005 what price can you do for me then for a 96 facelift sz-r then assuming i have i the small discs which i must have !! HERE are photos of the larger and smaller spec brakes, which should help you identify what you have. If you're not sure, post photos of the front and rears so we can see what you've got. If you email me at nicvollans @ netvigator . com I'll send you a price list for the larger spec brakes, including branded options for discs and pads. Link to comment Share on other sites More sharing options...
supra-alex Posted November 29, 2005 Author Share Posted November 29, 2005 HERE are photos of the larger and smaller spec brakes, which should help you identify what you have. If you're not sure, post photos of the front and rears so we can see what you've got. If you email me at nicvollans @ netvigator . com I'll send you a price list for the larger spec brakes, including branded options for discs and pads. done Link to comment Share on other sites More sharing options...
