whitesupratt Posted November 26, 2005 Share Posted November 26, 2005 I have bought this downpipe to De-cat my TT, but i constantly hear people on here talking about 'other mods' that need done when removing the cat, and im slightly confused Can i not just put this on, and job done? Mine is a completely standard J-spec TT. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted November 26, 2005 Share Posted November 26, 2005 You'll need a restrictor ring to stop over boosting, and then you should really put in a new fuel pump and fuel pressure regulator to allow for the extra fuel needed at higher boost levels. Do a quick search, many threads on this one.... Link to comment Share on other sites More sharing options...
GeordieSteve Posted November 26, 2005 Share Posted November 26, 2005 You'll be needing a FCD for the raise in boost. I'd advise a restictor ring as well Link to comment Share on other sites More sharing options...
Homer Posted November 26, 2005 Share Posted November 26, 2005 You could but it wouldn't run very well. You'll also need: Restrictor ring (e.g. CW) = £10 Walbro Fuel Pump = £100 Thor VFCD = £60 Colder grade plugs = £20 Fuel Filter = £25 If you don;t have one already you will need a boost gauge: DEFI Boost Gauge & Box = £200 Do you still have the standard cat-back exhaust? HTH Link to comment Share on other sites More sharing options...
whitesupratt Posted November 26, 2005 Author Share Posted November 26, 2005 i still have the factory everything, just a back box Link to comment Share on other sites More sharing options...
Homer Posted November 26, 2005 Share Posted November 26, 2005 Probably worth changing the cat back too, the standard one is very restrictive. You could pick up a decent one for around £400 (RSR/NUR tend to be the best priced) Link to comment Share on other sites More sharing options...
dangerous brain Posted November 26, 2005 Share Posted November 26, 2005 Boost gauges needn't cost you £200 you could get one for a lot lot less than that. Cat out OEM exhaust in should keep the boost below 1.0 bar which means you don't need any of the other stuff. There are more types of restrictor than a 1.2 bar one, I'm sure CW does a 1.0 bar one as well. Link to comment Share on other sites More sharing options...
whitesupratt Posted November 26, 2005 Author Share Posted November 26, 2005 iv already got a boost gauge, not fitted yet tho. Just need a pod for it. Link to comment Share on other sites More sharing options...
dangerous brain Posted November 26, 2005 Share Posted November 26, 2005 Keep the boost to .98 and you'll be ok Link to comment Share on other sites More sharing options...
Pete Posted November 26, 2005 Share Posted November 26, 2005 You could but it wouldn't run very well. You'll also need: Restrictor ring (e.g. CW) = £10 Walbro Fuel Pump = £100 Thor VFCD = £60 Colder grade plugs = £20 Fuel Filter = £25 If you don;t have one already you will need a boost gauge: DEFI Boost Gauge & Box = £200 Do you still have the standard cat-back exhaust? HTH Your prices are a little on the keen side there. Link to comment Share on other sites More sharing options...
whitesupratt Posted November 26, 2005 Author Share Posted November 26, 2005 Boost gauges needn't cost you £200 you could get one for a lot lot less than that. Cat out OEM exhaust in should keep the boost below 1.0 bar which means you don't need any of the other stuff. There are more types of restrictor than a 1.2 bar one, I'm sure CW does a 1.0 bar one as well. So i should be ok, just putting my downpipe on and having factory exhaust, Thats not the first time someone has said that to me, my local garage said unless id gone 3'' all the way, i would be ok. im in no rush to do it, but dont wana go through the hassel of fitting it, then it turns out i need the other stuff, and have to take off again! Eventualy ill get the other goodies, but im impatient...wana stick it on! Link to comment Share on other sites More sharing options...
whitesupratt Posted November 28, 2005 Author Share Posted November 28, 2005 just another quicky, is tht downpipe i have (pictures at the top) a full decat? Link to comment Share on other sites More sharing options...
LeeT Posted November 28, 2005 Share Posted November 28, 2005 just another quicky, is tht downpipe i have (pictures at the top) a full decat? it is a full decat pipe although it looks a bit different in shape to other pipes ive seen:shrug: Link to comment Share on other sites More sharing options...
whitesupratt Posted November 28, 2005 Author Share Posted November 28, 2005 Happy days! well if its wrong, the place i got it can 'ave it back and ill get a refund! Link to comment Share on other sites More sharing options...
toyotasuprauk Posted November 28, 2005 Share Posted November 28, 2005 Why do you need a new fuel filter? Link to comment Share on other sites More sharing options...
China Man Posted November 28, 2005 Share Posted November 28, 2005 I got the warbo with the fitting kit for less than that I think. FCD I got thor gauge, 2 down pipes, restrictor ring I got second hand plugs ik24 I fitted all I can myself and the rest Matt Harwood, Phenoix Not that expensive and very cost effective in terms of power gains. Going to get it RR with james those "lot" will be interesting to see the gains as I did rr there with a stock j-spec now I need to sort out a oil change and plug change. Link to comment Share on other sites More sharing options...
Jake Posted November 28, 2005 Share Posted November 28, 2005 you should really put in a new fuel pump and fuel pressure regulator Unusual advice there Ben. I don't think many people change the FPR for bpu. I certainly wouldn't want one of those rising rate FPRs like the FSE one. Link to comment Share on other sites More sharing options...
