veilsideTT Posted June 4, 2003 Share Posted June 4, 2003 Just got my HKS Super Sequential Blow Off Valve but the installation manual is all in Japanese!!! Does anyone have this manual in English at all or know a link to where I could find it. Thanx all Scott UK Link to comment Share on other sites More sharing options...
Thorin Posted June 4, 2003 Share Posted June 4, 2003 If you've got the Supra specific kit then it's just a straight replacement for the stock BOV, 10 minute job. If it's just the universal kit then you need a flange welding into a hard pipe kit and mounting on that. Link to comment Share on other sites More sharing options...
veilsideTT Posted June 4, 2003 Author Share Posted June 4, 2003 Ive got the supra specific kit. Just seems to be a lot of little pipes n clips with it and would like to make sure i get it right. Cheers for the reply Scott Link to comment Share on other sites More sharing options...
Bobbeh Posted June 4, 2003 Share Posted June 4, 2003 I fitted mine recently. Its dead easy, well some of the things to fit are a pain to get on, but its dead simple (coming from someone with no technical knowlage about cars) Goto MKIV.com, technical articles and then to the blow off valve section, scroll down toward the bottom of the page and there are 4 photos of the installed item which are detailed pics. You should be able to see where things go etc and where they plug in, might be a good idea to print them off so you can reference them during fitting. The bolt on the air intake pipe thingy is a real bastard to get off, and it is a bit tight (not much room to work in when fitting). Honestly its so easy to fit. GL (I have taken a load of pics from my install, just not uploaded them yet.) Link to comment Share on other sites More sharing options...
veilsideTT Posted June 4, 2003 Author Share Posted June 4, 2003 thanks for the info Bobbeh I will give it a shot! Link to comment Share on other sites More sharing options...
