Pig Posted November 2, 2005 Share Posted November 2, 2005 Tried doing a search. Need to know what to buy. Any one got any suggestions. I would rather something small and mounted possibly in the dash. Cheers Link to comment Share on other sites More sharing options...
Guest Terry S Posted November 2, 2005 Share Posted November 2, 2005 http://www.spa-uk.co.uk/design/dualgauges.asp DG206 or similar Link to comment Share on other sites More sharing options...
Pig Posted November 2, 2005 Author Share Posted November 2, 2005 Not into cheap stuff are you! lol. Is that easy enough to mount? and is that the same one you have in your car? Link to comment Share on other sites More sharing options...
Alex Posted November 2, 2005 Share Posted November 2, 2005 I'd go for the DG211 which is a full kit for monitoring Boost and EGT's. They will either fit where the clock is or in an airvent depending on whether they are 52 or 60mm. Link to comment Share on other sites More sharing options...
Pig Posted November 2, 2005 Author Share Posted November 2, 2005 whats egt? Link to comment Share on other sites More sharing options...
Guest Terry S Posted November 2, 2005 Share Posted November 2, 2005 Exhaust gas temperature yeah thats ( EGT) preferable but not sure you will fancy having the probe fitted John. These gauges do two things at once. The stock water temp gauge is naff so makes sense. They are easy to fit, and peak hold which is an another important feature. Link to comment Share on other sites More sharing options...
Alex Posted November 2, 2005 Share Posted November 2, 2005 Exhaust Gas Temperatures. These are key to knowing if you're engine is getting too hot. A way of warning you before you detonate and destroy your engine. Link to comment Share on other sites More sharing options...
Guest Terry S Posted November 2, 2005 Share Posted November 2, 2005 Not into cheap stuff are you! lol. Is that easy enough to mount? and is that the same one you have in your car? Yes I have 2 x SPA gauges but not the Boost gauge, thats done on the boost controller. Link to comment Share on other sites More sharing options...
Pig Posted November 2, 2005 Author Share Posted November 2, 2005 AHHHHH which one to buy!!!! I need to get one cause otherwise im gunna blow the lot. I am running a crumbling stock intercooler at the moment and still cant decide which FMIC to buy. which one gauge will be best of warning me that im gunna do damage related to the IC not doing much? Thanks for your help guys Link to comment Share on other sites More sharing options...
Guest Terry S Posted November 2, 2005 Share Posted November 2, 2005 DG211 as Alex said, but fitting the EGT probe is a job. Link to comment Share on other sites More sharing options...
Alex Posted November 2, 2005 Share Posted November 2, 2005 If you're worried about the stock IC then the EGT+Boost DG211 is for you. You can get an oil/water temp one later. I have a place in Norwich that will fit the probe for the EGT gauge into you exhaust. Link to comment Share on other sites More sharing options...
Pig Posted November 2, 2005 Author Share Posted November 2, 2005 Oh and this prob. where does that go? Apart from in the exhaust lol Link to comment Share on other sites More sharing options...
Pig Posted November 2, 2005 Author Share Posted November 2, 2005 Great could i take there number please? Will they be good to fit my fuel cut defenser? How much would they charge roughly for the EGT probe fitting Link to comment Share on other sites More sharing options...
Guest Terry S Posted November 2, 2005 Share Posted November 2, 2005 Oh and this prob. where does that go? Apart from in the exhaust lol Depends how brave you are, either immediately after the turbo/s or in a runner. Link to comment Share on other sites More sharing options...
Alex Posted November 2, 2005 Share Posted November 2, 2005 Oh and this prob. where does that go? Apart from in the exhaust lol In the exhaust manifold or just after the turbos... Link to comment Share on other sites More sharing options...
Alex Posted November 2, 2005 Share Posted November 2, 2005 lol - glad to see our quick fire responses tally eh Terry Link to comment Share on other sites More sharing options...
Guest Terry S Posted November 2, 2005 Share Posted November 2, 2005 LOL Alex, yeah we are here to help remember at least the answers match! Link to comment Share on other sites More sharing options...
Alex Posted November 2, 2005 Share Posted November 2, 2005 Great could i take there number please? Will they be good to fit my fuel cut defenser? How much would they charge roughly for the EGT probe fitting They are a fabrication shop only...ie I'd only go there for a bit of welding etc... I'll find the details and PM you...but buy the kit first then book - he's a busy man. Link to comment Share on other sites More sharing options...
Pig Posted November 2, 2005 Author Share Posted November 2, 2005 on how brave i am? You guys like to worry me dont you. Oh terry regards my exhaust im getting a bit of blow (according to toyota) from the join (decat to cat back) do i need to get it sorted asap or just next time im down pheonix way? Thinking of going to see mark cause running rich...not totally sure what to do about it. Bloody tunning cars. should have stayed stock lol Link to comment Share on other sites More sharing options...
Guest Terry S Posted November 2, 2005 Share Posted November 2, 2005 on how brave i am? You guys like to worry me dont you. Oh terry regards my exhaust im getting a bit of blow (according to toyota) from the join (decat to cat back) do i need to get it sorted asap or just next time im down pheonix way? Thinking of going to see mark cause running rich...not totally sure what to do about it. Bloody tunig cars. should have stayed stock lol OK the V band may need tightening a bit, nothing to worry about if it is. There isnt much he can do about running rich, they all do it from stock. He could fit a SAFC2 but its where to stop mate. Link to comment Share on other sites More sharing options...
Pig Posted November 2, 2005 Author Share Posted November 2, 2005 thats the problem. One big money pit. lol Thanks for the AMAZINGLY quick responces. Im now decided on the gauge. Is the SAFC2 worth the investment cause getting about -10 mpg. Link to comment Share on other sites More sharing options...
Guest Terry S Posted November 2, 2005 Share Posted November 2, 2005 mmm what is she doing to a tank(miles). The Airflow metre may be fubar. There is a spare sitting at Phoenix of mine. Link to comment Share on other sites More sharing options...
Pig Posted November 2, 2005 Author Share Posted November 2, 2005 about 230 i think. Not too good Link to comment Share on other sites More sharing options...
Guest Terry S Posted November 2, 2005 Share Posted November 2, 2005 about 230 i think. Not too good depends how you are driving mate. Link to comment Share on other sites More sharing options...
Pig Posted November 2, 2005 Author Share Posted November 2, 2005 Wouldnt say i drive looking for economy. Since resetting ECU after decat fuel consumption get way worse. havent done a full tank yet. if its gets really bad can i contact you to see about that airflow meter. Do i need to consider replacing the O2 sensor? Thanks for your help with the boost gauge, should i consider mark for fitting of the EGT probe? As was going to see him any way. p.s any luck getting hold of matt. Bought the FCD but wanted him to fit it Link to comment Share on other sites More sharing options...
