**msn Virus**
RobSheffield
Even if you click that link, it'll point you to the page where it asks you to download the file. I would recommend against clicking the link, unless you're using firefox. i have no idea how Internet Explorer would handle it, nor do i want to find out!
It drops a file called "svshost" into a hidden directory in the system32 folder. It blocks (at least) task manager and regedit, and sends itself to all the users on your list. To clean it i took it out of the run keys in HKCU and HKLM in safe mode, then deleted it from the prefetch and system32
Anyone got a step by step guide how to do this?
You need to boot in safe mode for a start (F8 whilst the system is loading I think).
Then look in C:\WINDOWS\system32\
in 'tools\folder options' you should click view and make sure that it is set to show hidden files and folders. Then find a folder that has an odd name (or you might need to look in them to find the file called svshost).
Just delete the file if you find it, if the virus software has got rid of the problem then you shouldn't need to worry about the registry entries.
