DASH Resprayed
Guest brutus
How many coats did you need with this stuff? And where's the best place to get it from? Cheers
You should be able to get it from your local Motor acc shop(Not HALFRAUDS) its in a Black AEROSOL, with 'HYCOTE' in Yellow on the front..1 tin will do the dash..2-3 coats, its concentrated,so goes on thicker than normal aerosols
Cool, cheers, I've seen it on a website but prob better to get it in a shop so i can see the colour! Sounds like a bitch to get the dash bits off though, but we'll see how it goes. I'll post some pics when I get round to doing it (prob in a month or so! :whistle: )
Hell yeah, from what i've heard the stick on bits scratch easily, and don't look as good anyway (yet they cost more!). I can't wait to do mine!!!
you can get some top quality kits........my own is LAMINATED brushed Ally, which is guaranteed scratch and fade resistant £89 from USA (EBay)
Pre-facelift Supras have a black rubber coating on all dash panels. You will need to remove it before spraying. It's not like a one-piece bit of rubber that you can peel off, it needs to be scraped off bit by bit.
If you want to see what it's all about, simply run your thumbnail across a bit of the dash somewhere (preferably a hidden away bit, try somewhere on the electric window switch) and watch the black stuff build up under your thumbnail.
Oh right, HOWEVER, as I'm new to the world of Supra I'm not sure whether mine is a pre or post facelift model!!!!!!!! It's a 1995 J-spec, what are the differences???????????????????????? :eek:
Hmmm, that does look pretty sweet actually. I thought they were all separate pieces but that looks like it's all one piece on the main section of the dash. Very nice indeedy!!! :yes:
Theres 3 seperate pieces,if you look closer on one of the pics, you can see the join either side of the clocks.
BTW..whereabouts in Cheshire are you?
