_Rob_ Posted October 17, 2005 Share Posted October 17, 2005 I know, i know, this topic has come up many times before! ive been doing searches and reading up but i am still a little confused. im thinking of an FMIC but am not sure which to get, i will be fitting it myself and it will more than likely be part of Nics group buy. my car is a 94 UK TT auto. Engine is stock apart from Nur spec exhaust and HKS SSQV BOV. near future plans are de-cat, plugs, FCD, up boost at 1.2bar, id like about 400 bhp. reccomnded FMIC's for this kind of set up on stock twins seems to be the greddy 2 row or HKS s-type. how ever people still seem to be buying 3 rows and the r type. will the smaller FMIC be sufficient for my setup and plans? or should i get the HKS r-type while im getting one? if the smaller one is ok, would anyone reccomend the greddy over the HKS? or vice versa. cheers guys! Link to comment Share on other sites More sharing options...
Lucifer Posted October 17, 2005 Share Posted October 17, 2005 Chris Wilson on here sells an uprated side mount which is best for your application. If you intend going much over that you will need a front mount. If you are an auto you will need a new fan also so adding to the cost and labour time. Greddy are a good bang for the buck. Link to comment Share on other sites More sharing options...
suprarob Posted October 17, 2005 Share Posted October 17, 2005 hi Rob I ,ve gone with the Chris Wilson smic just fitted it this week end its a good easy fit but you will have to persuade Chris to get some more made I think I bought his last one What you have to remember is with the fmic you loose your active spoiler Link to comment Share on other sites More sharing options...
Jake Posted October 17, 2005 Share Posted October 17, 2005 If you are an auto you will need a new fan also Why's that? What fan are you referring to? Thanks (Can you tell I've ordered a FMIC for my Auto? ) Link to comment Share on other sites More sharing options...
Ian C Posted October 17, 2005 Share Posted October 17, 2005 I'm interested in that fan comment too -Ian Link to comment Share on other sites More sharing options...
Sharpie Posted October 17, 2005 Share Posted October 17, 2005 Me too Link to comment Share on other sites More sharing options...
Lucifer Posted October 17, 2005 Share Posted October 17, 2005 Ok..... If you are an auto with a FMIC you have to remove the Stock electric fan (trust me you have to!) - This is the big one in the cage that sits infront of the AC rad. Now you have 2 options here. 1. Run stock ish power and dont ever use the AC on a hot day. 2. Run BPU+++ and the Aircon but buy a SPAL slimline fan. - 2 if you can stretch to it. You will see the fan I am refereing to in one of my pictures in my upgrade project. Even if your Cooling system is 100% , which lets face it prob not the case on our millage cars... you will still need this fan in the Summer. The reason for this is that a FMIC restrict airflow to the Radiator, the fan helps it on its way. £70 and a bit of fabing or a cooked engine...... As part of that upgrade I also Suggest buying a TRD STAT. Martin Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 17, 2005 Share Posted October 17, 2005 4 more SMIC's are in build, due to demand having suddenly risen again (And the fact someone VERY kidly let me sell "his" SMIC to someone who was desperate to get his car back in action after an accident...). Link to comment Share on other sites More sharing options...
Steve Posted October 17, 2005 Share Posted October 17, 2005 Wasnt Dudes car running 650hp ish on a Greddy 2 row FMIC? So dont think there is a issue of it being too small! Link to comment Share on other sites More sharing options...
_Rob_ Posted October 17, 2005 Author Share Posted October 17, 2005 So is the general feeling to go with a CW SMIC? i hadnt even considered these. what sort of price are these from Chris? ive not seen that about the fan before, do you mean the large fan to back of the rad? hmm, decisions! could anyone tel me the dimensions of the CW SMIC as compaerd to the stock sidemount? Link to comment Share on other sites More sharing options...
Steve Posted October 17, 2005 Share Posted October 17, 2005 Think the dimensions are the same just has a thicker core. Could be wrong though Link to comment Share on other sites More sharing options...
Graham S Posted October 17, 2005 Share Posted October 17, 2005 if its anything i made 404 bhp on just decat and exhaust! but i'm manual! Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 17, 2005 Share Posted October 17, 2005 Info on my SMIC's below. thanks. Is your intercooler falling apart, the fins corroded off the tubes? If so, its efficiency will be extremely degraded. Running more boost than stock? Is this a good idea? NO! It's not even a good idea running STOCK boost with an I/C like that, and when the weather struggles above freezing it will be a VERY BAD idea! Don't want to spend over 1400 quid on a new quality front mount intercooler, only to have half of it masked by the aperture in the front stock bumper being too small to allow air through all the core? Even with a new aftermarket bumper that probably fits where it touches, (from what I have seen of most Jap products), the air will just take the easy route AROUND the expensive FMIC, rather than through it, because no ducting provision is made. The answer is my uprated, all aluminium stock mount intercooler. It uses all original mountings, and the original factory sealed ducting. It uses a state of the art core with fine pitched finning, on modern tubes with internal turbulators. The core uses 10% more tubes than the stock unit, too. The quality of its construction is superb, and all are fully leak tested under pressure before despatch. Pressure drop, both internally through the core, and aerodynamically, are less than the stock cores, making for a very efficient unit. Pics of the intercooler are now available at: http://www.formula3.freeserve.co.uk/intercooler/intercooler.zip or http://www.formula3.freeserve.co.uk/intercooler/intercooler.html They will sell for 610 pounds, there is no VAT to pay. Postage and packing to UK mainland addresses is 12.50, the package is bulky due to their fragile nature. Link to comment Share on other sites More sharing options...
Lucifer Posted October 17, 2005 Share Posted October 17, 2005 Chris, I would be veru interested for you to say weather is would support a single turbo application up to say around 6-700 with supporting mods or would you say 3-4row FM? Cheers. PS**** If you are only BPU GO WITH CHRIS'S!! Link to comment Share on other sites More sharing options...
paul mac Posted October 18, 2005 Share Posted October 18, 2005 Ok..... If you are an auto with a FMIC you have to remove the Stock electric fan (trust me you have to!) - This is the big one in the cage that sits infront of the AC rad. Now you have 2 options here. 1. Run stock ish power and dont ever use the AC on a hot day. 2. Run BPU+++ and the Aircon but buy a SPAL slimline fan. - 2 if you can stretch to it. You will see the fan I am refereing to in one of my pictures in my upgrade project. Even if your Cooling system is 100% , which lets face it prob not the case on our millage cars... you will still need this fan in the Summer. The reason for this is that a FMIC restrict airflow to the Radiator, the fan helps it on its way. £70 and a bit of fabing or a cooked engine...... As part of that upgrade I also Suggest buying a TRD STAT. Martin or get yourself down to the local scrap yard with a big hammer and smash the f**k out of old cars (its great) and pick up up a bargain for £2, i think this came out of a nissan sunny, to be fair i think you can run the air con with no probs just dont expect freezing air when stuck in a traffic jam at 90 degrees Link to comment Share on other sites More sharing options...
Lucifer Posted October 19, 2005 Share Posted October 19, 2005 or get yourself down to the local scrap yard with a big hammer and smash the f**k out of old cars (its great) and pick up up a bargain for £2, i think this came out of a nissan sunny, to be fair i think you can run the air con with no probs just dont expect freezing air when stuck in a traffic jam at 90 degrees ERRR ok... so where is your fmic then? Link to comment Share on other sites More sharing options...
Sharpie Posted October 19, 2005 Share Posted October 19, 2005 Ok..... If you are an auto with a FMIC you have to remove the Stock electric fan (trust me you have to!) - This is the big one in the cage that sits infront of the AC rad. As part of that upgrade I also Suggest buying a TRD STAT. Martin I see, I did not install my FMIC so, did not see this. - I have seen your aftermarket fan but, do you have any pic's of the stock one in situ ? My AC is warm in summer due to no fan ......I HAVE to add one for next summer! Link to comment Share on other sites More sharing options...
Lucifer Posted October 19, 2005 Share Posted October 19, 2005 I see, I did not install my FMIC so, did not see this. - I have seen your aftermarket fan but, do you have any pic's of the stock one in situ ? My AC is warm in summer due to no fan ......I HAVE to add one for next summer! Sorry no, but you cant miss it, it has a large mesh cage around it, anyone got a pic... maybe from teh tech manual.... Actually try mkiv.com for tha manual.... Link to comment Share on other sites More sharing options...
Ian C Posted October 19, 2005 Share Posted October 19, 2005 Ahhh, so *that's* what that fan is for. I saw one once and thought it was an aftermarket cheapo bolt on because it looks so un-OEM! Then I saw it on another Supra and thought "wtf?" which is why I was interested in this - I figured you had the answer to what this fan is for... Still can't believe it's stock, it looks shite. Paul's £2 one looks better! -Ian Link to comment Share on other sites More sharing options...
Sharpie Posted October 19, 2005 Share Posted October 19, 2005 This one.. Link to comment Share on other sites More sharing options...
Sharpie Posted October 19, 2005 Share Posted October 19, 2005 So, my stock UK car back in 2003 never had a fan ? I thought the rad you can see through the vent is the AC rad ? Link to comment Share on other sites More sharing options...
Lucifer Posted October 19, 2005 Share Posted October 19, 2005 So, my stock UK car back in 2003 never had a fan ? I thought the rad you can see through the vent is the AC rad ? Its a secondary fan which operates all teh time the ac is on, but sometimes if the car is hot. Interesting your UK one does not have one... another difference maybe? Link to comment Share on other sites More sharing options...
Pig Posted October 19, 2005 Share Posted October 19, 2005 my uk doesnt seem to either Link to comment Share on other sites More sharing options...
Sharpie Posted October 19, 2005 Share Posted October 19, 2005 No, I think this is where my understanding of "how many rad's" the car has and in which order they are presented in falls short....... Below it the UK AC rad from EPC. I'd like to be corrected here so, jump in The AC rad sits infront of the Water Rad right ? I *thought* that there was a smaller fan for the AC which, was below and to the left of the viscous (sp?) fan - looking from the drivers seat which, has it's own part of the "main" shroud for protection too ?? HOWEVER - If you are saying that there is a fan infront of the AC rad, then does this mean there is a 3rd rad ? what is the rad you can see through the vent (mouth) in the pic above then ? Link to comment Share on other sites More sharing options...
Sharpie Posted October 19, 2005 Share Posted October 19, 2005 Here is the 2nd fan Link to comment Share on other sites More sharing options...
