Manual conversion parts wanted
G9RGE
 Share
I'm buying a w58 manual gearbox to fit to my Na auto.
I should be getting all the gearbox bits such as flywheel/clutch fittings, along with the 1st half of the pro and the gearbox mount.
That leaves me needing a clutch pedal- brake pedal- the modified tunnel section, slave cylinder and anything else anyone can think of.
If you have any of the above please let me know 👍
The manual tunnel section is only available from Toyota, it’s not expensive. Slave cylinders are fairly cheap too. You’ll need the gearbox mount too and a lot of other little bits. I buy from amayama which supplies oem parts direct from Japan. It’s much cheaper than a uk dealer but has longer lead times.
 Share
