shervin_ice Posted May 28, 2023 Share Posted May 28, 2023 (edited) Hi guys, i recently noticed there is a clunky noise coming from rear driver side Suspension on small bumps its like something hitting on the metal so i jacked the car up and checked and found the there a rubber seats under the top mount metal plate and it looks like its worn and when i tried lift the wheel up and down make that noise so i think i need to replace it so wondering if anyone knows where and how i can order them or any suggestions?it looks like i need to change them all 4 thanks in advance Edited May 28, 2023 by shervin_ice (see edit history) Link to comment Share on other sites More sharing options...
Swampy442 Posted May 28, 2023 Share Posted May 28, 2023 Sounds like you need a new top mount, where you'd get one from, absolutely no idea, best bet would be Japan Link to comment Share on other sites More sharing options...
shervin_ice Posted May 28, 2023 Author Share Posted May 28, 2023 1 hour ago, Swampy442 said: Sounds like you need a new top mount, where you'd get one from, absolutely no idea, best bet would be Japan I looked everywhere online but couldn’t find anything so i might as well start looking for it in Japan 1 hour ago, Swampy442 said: Sounds like you need a new top mount, where you'd get one from, absolutely no idea, best bet would be Japan Link to comment Share on other sites More sharing options...
Swampy442 Posted May 29, 2023 Share Posted May 29, 2023 Depending on how old they are they might be discontinued now Link to comment Share on other sites More sharing options...
Swampy442 Posted May 29, 2023 Share Posted May 29, 2023 You didnt look very hard then....... Bump rubbers. Hopefully they have what you need. Obviously replace all 4 at once https://www.hksusa.com/products/hipermax-series-optional-parts/43 Link to comment Share on other sites More sharing options...
shervin_ice Posted June 1, 2023 Author Share Posted June 1, 2023 On 5/29/2023 at 8:01 AM, Swampy442 said: You didnt look very hard then....... Bump rubbers. Hopefully they have what you need. Obviously replace all 4 at once https://www.hksusa.com/products/hipermax-series-optional-parts/43 I think these are for supra A90 Gr as nothing comes up for mkiv but maybe they are the same ,I found these old hks i had in my storage but not sure if they are the same Link to comment Share on other sites More sharing options...
