Hks Hipermax III clunky noise from rear driver side
shervin_ice
 Share
Hi guys,
i recently noticed there is a clunky noise coming from rear driver side Suspension on small bumps its like something hitting on the metal so i jacked the car up and checked and found the there a rubber seats under the top mount metal plate and it looks like its worn and when i tried lift the wheel up and down make that  noise so i think i need to replace it so wondering if anyone knows where and how i can order them or any suggestions?it looks like i need to change them all 4 ☹️
thanks in advance
Edited by shervin_ice (see edit history)
1 hour ago, Swampy442 said:
Sounds like you need a new top mount, where you'd get one from, absolutely no idea, best bet would be Japan
I looked everywhere online but couldn’t find anything so i might as well start looking  for it in Japan 😀
On 5/29/2023 at 8:01 AM, Swampy442 said:
You didnt look very hard then....... Bump rubbers. Hopefully they have what you need. Obviously replace all 4 at once
https://www.hksusa.com/products/hipermax-series-optional-parts/43
I think these are for supra A90 Gr as nothing comes up for mkiv but maybe they are the same ,I found these old hks i had in my storage but not sure if they are the same
 Share
