baldy Posted August 5, 2021 Share Posted August 5, 2021 So cars been parked up a few years, the wipers run if i put a direct supply to the plug on the motor. The stalk is sending different supplies to different pins in the loom at the motor depending on off on and on at 2nd speed, but if the loom is plugged in nothing but washers work! any ideas please peeps Link to comment Share on other sites More sharing options...
m12aak Posted August 5, 2021 Share Posted August 5, 2021 Sounds odd for sure, hopefully it's something simple. Have you checked all the fuses are in/unbroken (I'm sure you would have, but just in case!) Sounds like it could just be a broken fuse not supplying any power, as I believe the stalk still provides signals even when the fuse is blown. If it's not that, I'd probably be taking a look at the 'Body Electrical' service manual for further diagnostics and failing that, the wiring diags. Link to comment Share on other sites More sharing options...
Frank Bullitt Posted August 5, 2021 Share Posted August 5, 2021 All horrible suggestions from me I’m afraid. Can you opened the plugs up? If you can’t, try de-pinning each one, checking the connection is solid, clean it and put it back. Maybe look soldering if any cables are loose. What are the connections like on both plugs? Fractured cable? Has anything on the loom been accidentally pinched? Link to comment Share on other sites More sharing options...
baldy Posted August 5, 2021 Author Share Posted August 5, 2021 After looking at wiring diagrams i think its a bad earth, will take a look again tomorrow fuse is all good 1 Link to comment Share on other sites More sharing options...
