NA-T COP conversion KIT GTE coils
Robbieg1994
 Share
Hi everyone, here for sale I have the coil on plug conversion kit that was meant to go on my NA-T Supra.
The kit includes a set of used and a set of new GTE coil packs, a mounting bracket to fit on a GE head, all the pigtails and wiring for the coil packs and a GTE igniter with the plug and wiring.
This is the perfect setup if you are thinking of doing the TT ECU to go turbo on a budget. A friend of mine uses this same setup on his 1000hp 3.4 stroker so it's perfectly capable of holding more power than the TT ECU can give.
I also have a GTE MAP sensor for sale too with the pigtail aswell.
I would like GBP 350 for the whole set but I am open to offers.
I would prefer to post due to covid but pickup is possible aswell.
Cheers!
Rob
2 hours ago, Robbieg1994 said:
Hi Nathan,
They can be made to fit but you are best off running a front facing intake manifold. I had a TT intake manifold modified to fit on NA runners.
Cheers,
Rob
Interesting. Did you use an adaptor plate or have it welded? Did it hit the bonnet at all?
Mine was modified by adding material and grinding so it was a direct bolt up. It touched the insulation but didnt touch the metal part of the bonnet.
image.png.842ce22b68b720db1b9acd61ef428afe.pngimage.png.0892ba0843472fe94dc3e126a6973469.png
I sold it as I am now going DBW and a different standalone.
2 hours ago, Nathanj1142 said:
currently doing NA-T myself but keeping the stock GE intake as i've got the whifbitz kit so all piping matches up. Might do this next winter! Will probs go aftermarket but I imagine this being a cheaper and better method rather than buying a sh!t plenum
Whifbitz do a coil kit that fits the GE intake.
Sorry hijack thread.
Lovely kit for the price. Especially with mounting bracket.
 Share
