bluesonic94 has discovered that U.K. spec Supra's use the A343E box!
(Why after all these years has a U.K. spec owner not revealed this before now?) :shrug:
What this means is; the A343E box is as strong as the A340E and like the Aristo A340E, it can have the prop flange and breather swapped to become a plug & play fit into Supra.
Note: V8 and S6 bell-housings are different but are a straight swap.
This information greatly increases the number of transmissions to choose from as they wear out with time. :yahoo:
WELL DONE TREVOR.
Thank you. :thumbs:
A343E
Torque converter with lockup clutch and 4 - steps - automatic with overdrive ( Aisin A340 / A340E / A343E ) - [ E = electronically controlled ]
Turbo - models equipped Toyota standard with a differential with limited slip by the Torsen ® system and a ( by pressing a button can be switched off ) electronic traction control ( TRC ) from .
body Coupe / Targa Coupe / Targa
engine 2JZ - GE 2JZ - GTE
transmission 4 - Gang - Automatic ( A340 / A340E ) 4 - Gang - Automatic ( A340E / A343E )
6 - gear - gear ( Getrag V161 ) 6 - gear - gear ( Getrag V160 )
5 - gear - gear ( W58 )
Torsen - differential optional default
( USA: standard from 1998 )
Transmission Grading / Differential
engine region transmission Gear / translation differential total translation
1 2 3 4 5 6 R
2JZ - GTE EU A343E 2 , 804 1 , 531 1 , 000 0 , 753 2 , 393 3 , 538 2 , 664
Austria / CH A343E 2 , 804 1 , 531 1 , 000 0 , 753 2 , 393 3 , 266 2 , 459
USA / Japan / GCC A340E 2 , 804 1 , 531 1 , 000 0 , 705 2 , 393 3 , 769 2 , 657
EU V160 3 , 827 2 , 360 1 , 685 1 , 312 1 , 000 0 , 793 3 , 280 3 , 266 2 , 590
USA / Japan / GCC V160 3 , 827 2 , 360 1 , 685 1 , 312 1 , 000 0 , 793 3 , 280 3 , 133 2 , 484
2JZ - GE USA / GCC A340 / E 2 , 804 1 , 531 1 , 000 0 , 705 2 , 393 3 , 769 2 , 657
Japan A340E 2 , 804 1 , 531 1 , 000 0 , 753 2 , 393 4 , 083 2 , 879
USA W58 3 , 285 1 , 894 1 , 275 1 , 000 0 , 783 3 , 786 4 , 272 3 , 345
USA ( from 1998 ) W58 3 , 285 1 , 894 1 , 275 1 , 000 0 , 783 3 , 786 4 , 083 3 , 197
Japan W58 3 , 285 1 , 894 1 , 275 1 , 000 0 , 783 3 , 786 4 , 083 3 , 197
GCC ( Gulf States ) W58 3 , 285 1 , 894 1 , 275 1 , 000 0 , 783 3 , 786 3 , 769 2 , 951
Japan V161 3 , 724 2 , 246 1 , 541 1 , 205 1 , 000 0 , 818 3 , 192 3 , 269 2 , 674
After the 4 gear ratio's same, the next is ? the next is diff ratio and the last is ?
 Share
