Covet Thy Nuts & Bolts
When buying a "complete transmission", if it's not complete with cross-member, nut's, bolts, washers, oil-lines and donut etc sufficient for your requirement,
haggle the price down hard.
Pay attention to these little things, because you could easily end up paying more for nuts & bolts than you did for the transmission!
These 'insignificant' ( "Easy fix mate" :Pling: ) components are difficult to source used and new ones add up to arms and legs.
For reference, here's a list of all these little bits & pieces, with part no.s and prices too when they come my way.
The waaaaay out of date Toyodiy $ prices are there to give you a clue.
Should you have information of any recent prices in £ GBP, please don't be too :zzz: complacent to let me know and I can then :run: update the price & credit. :)
Thank you. :hi:
SPACER, DRIVE PLATE, FRONT
32116-22020 1 $29.18
SPACER, DRIVE PLATE, REAR
32117-22020 1 $14.98
Flex-plate to crank bolt
90105-10294 *10-1.25PX22-15 x 8 (When using used, ensure there's a number "11" on the head) $1.34
Flex-plate to torque converter bolt
90105-10340 *10-1.5PX12.8-9.8 x 6 (When using used, ensure there's a number "11" on the head) £1.00 + VAT. :hi: Delboy52
Bell-housing to transmission bolt
90119-10232 *** STD. PART x 4 $1.50
90119-12036 *** STD. PART x 2 $2.10
CROSS-MEMBER SUB-ASSY, ENGINE REAR MOUNTING
57255-14230 (05/1993 - 04/1995) $250.74
57255-14231 (05/1995 - ) $239.44
Cross-member to chassis bolt
90119-10551 *** STD. PART x 4 $2.06
Rubber mount - transmission to cross-member.
INSULATOR, ENGINE MOUNTING, REAR NO.1 12371-46120 $92.60
Cross-member to rubber mount nuts x 4 90179-08159 *** STD. PART $1.27
Transmission flange to prop NUT
90179-11017 x 4 £2.66 + VAT. :hi: bluesonic94
WASHER, NO.2 (FOR PROPELLER SHAFT)
90201-11013 x 4 £0.90 + VAT. :hi: bluesonic94
BOLTS, NO.1 (FOR CENTRE SUPPORT BEARING)
90119-10217 40 x 2 $2.10
WASHERS, NO.2 (SPACERS FOR CENTRE SUPPORT BEARING)
90201-10123 2.0 x 2 (matched to shell) $1.38
90201-10125 4.0 x 2 (matched to shell) $2.02
90201-10127 6.0 x 2 (matched to shell)$2.33
90201-10128 8.5 x 2 (matched to shell) $4.15
Prop to Diff
COUPLING, FLEXIBLE (Size "B" Donut)
37511-30020 $354.17
BOLTS (FOR FLEXIBLE COUPLING)
90105-12265 *12X1.25PX59.5-20 x 3 $10.83
NUTS (FOR FLEXIBLE COUPLING)
90179-12128 x 3 $1.38
WASHERS, PLATES (FOR FLEXIBLE COUPLING)
90560-12059 x 3 $5.89
 Share
