How-To Clean & Test Solenoids + Fit New Strainer
How-To Clean & Test Transmission Solenoids & Fit New Strainer
Drain sump and remove the nineteen 10mm head pan-bolts, start them gently, threads are open at the back and can sometimes be seized in, if so use WD 40 and be careful
Using a "broad tool" prise off the pan, a blunt 2" wood chisel is perfect for this job
Easily do-able with the car on axle stands
(pic :hi: evinX )
With sump pan removed the solenoids are easily get at-able, 3 in GE and 5 in GTE
Tip: Each time fit new strainer, pull out solenoids and give them a blast with aerosol brake-cleaner
GE valve-body with strainer
GE valve-body without strainer
Pic of 2 sets of N/A solenoids (Smaller ones are used from Facelift onwards - note different position of connectors)
Top one(s) are "normally closed" and bottom two(s) are "normally open".
T.T. valve-body with strainer (Gear-change and lock-up solenoids are the group of 3 smaller ones at the rear of the valve body, one is hiding underneath)
T.T. valve-body without strainer (Gear-change and lock-up solenoids are the group of 3 smaller ones at the rear of the valve body, one is hiding underneath)
Un-clip loom, (be gentle - the plastic may be brittle) remove the 10mm bolt on strap and pull solenoid out of valve-body.
To check that it functions; hold terminal pin to body across a 12v battery and see if it clunks, if it does it's working. :)
If dead replace, if good, clean with aerosol brake cleaner & refit, remember to inspect o-ring and please use a torque wrench at 7ftlb.
Check all 10mm head bolts on valve-body are @ 7ftlb whilst you are in there. (They grow loose over time)
How-To Re-Seal Sump here. http://www.mkivsupra.net/vbb/group.php?discussionid=176&do=discuss
If an N/A transmission solenoid has died, you can get a new design "compact" set for sensible money here.
http://www.ebay.co.uk/itm/A340-AW4-TRANSMISSION-SOLENOID-KIT-3PC-Shift-TCC-A340E-A340F-99109-/191627748841?hash=item2c9de765e9:g:7vgAAOSwyDxXguIS
Tip: Pre-Facelift and Facelift N/A transmissions have a different internal loom, the solenoid connectors are not same.
  • 3 weeks later...
  • 3 weeks later...
 Share
