David P Posted February 13, 2016 Share Posted February 13, 2016 "Will this thing fit in there?" "Which way would you like your cat skinning?" . . . . . . . . . http://www.mkivsupra.net/vbb/showthread.php?330945-Aristo-2JZGTE-AUTO-GEARBOX-TORQUE-CONVERTER-AND-FLYWHEEL-JZS161&p=4116746#post4116746 A Hybrid can be built using for a base platform, either a Supra T.T. or an Aristo 4-speed auto transmission, a Tiptronic could be used, but why would you want to? The valve-body and a few other bits come from a donor Supra N/A, or GS300 transmission, it's the most efficient version of the series and beefing-up a box is what it's all about. A Soarer v.b. could be used, but why would you not want the best option? A Hybrid will mate up to 2JZA80-GE & GTE, 1JZA80-GE & GTE & 1UZ-FE inc VVT-i variants, and 7M series engines using a mix & match of all OE components. A Hybrid will fit into a Supra, Soarer, Aristo or Lexus, using all OE components. Link to comment Share on other sites More sharing options...
David P Posted February 13, 2016 Author Share Posted February 13, 2016 A Hybrid is plug & play compatible with ECU; Supra Mk3 GTE & GE, Supra Mk4 GE, Soarer 1J-GTE, 2J-GE & V8, GS300 & 400. A Hybrid also functions with Suprastick ECU, providing 2 x sets of fully programmable gear-change tables & manualised flappy-paddle changes. A Hybrid could also function with Supra T.T. or Aristo ECU, by fitting line-feed pressure control-cable & resistors to redundant line-feed solenoid-wires. It has taken a while to work out which OE what, it takes to mate to which alternative OE other, in that OE space & the different computations are numerous. I refer to them as "Recipe's", and much depends on car/engine combo & what OE components are available at the time, no two installations are quite the same, similar yes, same no. Before embarking on any shopping. Contact Me and I'll provide you with an Ingredient List for your Bespoke 600ftlb Recipe. Link to comment Share on other sites More sharing options...
David P Posted March 4, 2016 Author Share Posted March 4, 2016 In the pages of this Group, I have done my damnedest with pretty pictures, videos and lots of writing in old-money, explaining how this upgrade works, yet at the dumbest level...... Automatic transmissions are like Tesco's. "Every little helps." In a nutshell! I take the weakest links out of the chain and replace them with a mix & match of strongest compatible OE components and build a beefed-up transmission that's plug & play with earlier generation electronics. Or if you prefer? It's all done with Magic! http://www.katzy.dsl.pipex.com/Smileys/magic2.gif How-To Get a Hybrid: http://www.mkivsupra.net/vbb/group.php?discussionid=90&do=discuss Link to comment Share on other sites More sharing options...
David P Posted March 11, 2016 Author Share Posted March 11, 2016 Formula Hybrid Strongest box; TT, Aristo & Tiptronic. Strongest torque-converter; TT, Aristo & Tip. (Thickest bolts 12MT x 1?) Strongest bolts - t.c. & crank; TT, Aristo & Tip. (no. 11's) Flex-plate; TT, Aristo, Tip or GS430. (Bigger bolt holes - V8 t.c. & f.p. parts are a lottery) Most efficient compatible valve-body; Supra N/A or GS300. Bell-housing from; engine type used. Transmission cross-member; TT, Aristo, Lexus 5-speed, 2J VVT-i's, LS400, Soarer V8 or GS430. Sump, dipstick & tube, for 1 & 2J; TT, Aristo or Tip. (Larger than GE S6 fluid capacity - largest is GS430 5-speed + re-cal dipstick) Sump, dipstick & tube, for 1UZ; GS430. (Largest V8 fluid capacity + re-cal dipstick) Prop-shaft front section; car box taken from. Prop-shaft tail-section; car box going into. Line-feed cable from; car going into, or bespoke. There are a few internal bits and pieces to swap & tinker with that I have not divulged, to prevent tears. Link to comment Share on other sites More sharing options...
David P Posted August 5, 2016 Author Share Posted August 5, 2016 Fluid Lines Fitting a Hybrid into Supra 2JZA80-GE, the plumbing requires a position adjustment to accommodate the 18mm deeper bell-housing. Fitting a Hybrid into any 1UZ-FE build, a bottom/front Supra pipe is required. Temperature Sensor The transmission has a temperature sensor that can multi-task and drive a temperature gauge to monitor fluid temp. Sump & Dipstick The bigger the sump, the bigger the fluid capacity and the bigger the better. A340E GE sump smallest, A340E GTE sump + 1 litre, A650E 5-speed sump largest. Hybrid with T.T. sump, all 2J installations use T.T. dipstick & tube. Hybrid with 5-speed sump may require re-calibration of dipstick to read correctly? Link to comment Share on other sites More sharing options...
David P Posted August 5, 2016 Author Share Posted August 5, 2016 Torque-Converters Either GTE or 1UZ torque-converter can be used with a Hybrid. GTE = 2,800 stall. 1UZ = 2,400 stall. Oil Coolers It is essential to use an additional oil cooler(s). ATF The good stuff is costly, but please don't skimp at this last hurdle, Toyota Type IV & a bottle of Lucas SS is my recommendation. Feedback Here Link to comment Share on other sites More sharing options...
