T.T. Auto Propshaft Info
With a finger-full of grease on the splines, it fits together in the configuration shown in this pic.
When collating the components, remember you need a T.T. prop/diff size donut.
The 4 x transmission to prop-shaft nuts are: M11 - 1.0 thread, part no. 90179-11017, £2.24 each + VAT from Mr T, if you forgot those.
Nuts & bolts for prop to diff are same for N/A & T.T.
The "thick washers" on centre-mount bolts, are spacers that locate between mount and body.
Torque settings here: http://www.mkivsupra.net/vbb/group.php?discussionid=130&do=discuss
If you suspect the prop is out of phase, try turning 180 degrees and reassembling.
 Share
