suprano Posted October 11, 2020 Share Posted October 11, 2020 Hello all I have uk spec brakes looking for new disc and pads what would you go for, and what is the disc size difference between jap and UK spec, cheers Link to comment Share on other sites More sharing options...
m12aak Posted October 11, 2020 Share Posted October 11, 2020 Hi, I got my TT brakes from a guy in the US running high HP so mine came with Stoptech drilled and slotted discs and aggressive pads (which are surprisingly good even without heat in them), so someone else would need to recommend something easier to get from the UK (maybe OEM discs with CW pads?), I can however help you with the size differences, see them below: UK (4p/2p) Front - 323mm diameter 30mm thick Rear - 324mm diameter 16mm thick Jap (2p/1p) Front - 296mm diameter 32mm thick Rear - 307mm diameter 16mm thick Link to comment Share on other sites More sharing options...
Dnk Posted October 12, 2020 Share Posted October 12, 2020 I'd go with OE discs and pads if its just for road use Link to comment Share on other sites More sharing options...
