Nathanj1142 Posted January 3, 2020 Share Posted January 3, 2020 Hey all, need the part number for the 4 pin connector on the loom that is used for the clock in the dash. I have a genuine analogue clock, not sure if its a different pin out. A wiring diagram would be perfect aswell as cant find anywhere. Cheers, Nathan. Link to comment Share on other sites More sharing options...
Mk4Gaz Posted January 3, 2020 Share Posted January 3, 2020 Plugs are the same, but the clocks are different. The analogue 'facelift' clock is bigger, and has a different fixing pattern. You'd need a prefacelift dash panel to use the digital clock, if your car is facelift. Link to comment Share on other sites More sharing options...
Marty Posted January 3, 2020 Share Posted January 3, 2020 I have a pre facelift clock wiring diagram if you need it.Clock.pdf Link to comment Share on other sites More sharing options...
inazone Posted January 4, 2020 Share Posted January 4, 2020 I have a pre facelift clock wiring diagram if you need it.Tried opening the pdf but it seems to be corrupt? Link to comment Share on other sites More sharing options...
Marty Posted January 4, 2020 Share Posted January 4, 2020 Works fine for me? Although i am using my laptop. Link to comment Share on other sites More sharing options...
blythmrk Posted January 4, 2020 Share Posted January 4, 2020 Tried opening the pdf but it seems to be corrupt? /QUOTE] Sent it you via whats app Link to comment Share on other sites More sharing options...
