Help Rear Diff
philw99
As Scooter said or you can put the internals from that in to yours. Personally it would strip the lot and rebuild using new OEM parts from Toyota.
Whilst apart it would also give you the opportunity to give the important parts a DCT treatment for extra strength/longevity.
Edited by Frank Bullitt
Spelling. (see edit history)
  • 3 months later...
Update to this thread, finally! :) i work at snails pace on most jobs unfortunaley :(
I've had the crown wheel and final drive pinion removed from the Lexus SC430 Diff, now the big question.... is this the correct one?
The only identifying marks on each part, crown wheel 0040524Y (Last 3 letters or numbers are hard to make out) Final drive pinion 0405251 (Really clear)
Number of teeth on the crown wheel is 49
Number of teeth on final drive pinion is 15
My simple maths 49 dvided into 15 = 3.266666666666667
Picture attached, it's a 200mm crown wheel as well, can anyone tell me if this will fit in a Supra N\A small case diff?
My current Diff "A01A - 4.083:1; small case 200mm; open"
Edited by philw99 (see edit history)
Hi Phil.
As both Scooter and myself said above, it will fit. You just need to strip your diff with the A01B & 4.083 swap ratios then put it back inside.
Edited by Frank Bullitt (see edit history)
Hi Phil.
Thanks guys.. will try and orgainse someone to swap it for me :) any sugestions on who?
