evinX Posted August 17, 2018 Share Posted August 17, 2018 Hi all, question for my mate who has a TT6 engine/box/diff and has a NA manual speedo cluster. The fuel and temp work and we got the Tach working by bridging the resistor, we found that info on the forum, But were struggling to get the Speedometer to work correctly, it moves but its somewhat lagging. Are there any tips on getting it to work? could it be the speed sensor causing the issue, different between NA and TT manual box? cheers Link to comment Share on other sites More sharing options...
keron Posted August 17, 2018 Share Posted August 17, 2018 the speedo should work exactly the same so sounds like either the speedo is faulty, converter/wiring or the speed sensor maybe? if he knows the speedo was working when the tt6 stuff was in another car, then will be speedo/ converter /wiring maybe Link to comment Share on other sites More sharing options...
evinX Posted August 17, 2018 Author Share Posted August 17, 2018 the speedo should work exactly the same so sounds like either the speedo is faulty, converter/wiring or the speed sensor maybe? if he knows the speedo was working when the tt6 stuff was in another car, then will be speedo/ converter /wiring maybe Ok cheers Keron, ill let him know Link to comment Share on other sites More sharing options...
