Oil cooler
K22SUP
 Share
Hi guys I am reinstating an aftermarket oil cooler that needed changed I have also fitted a mocal thermostatic take off plate rather than non thermostatic which was there I just want to double check hose route with any of you I have it from going out sandwich plate to oil cooler from cooler to remote filter head then from filter back to sandwich plate I’d thus the best way or anyone any different routes
Normally I go:
Sandwich Plate > Remote Filter > Cooler > Sandwich plate
Better to have filtered oil going to cooler rather than unfiltered incase you get any crud going into cooler.
Thanks mate it has never been that way but I might re route it
Id have it the other way, filter after cooler, to pick up any crap that may come out of the cooler
Hi I work in Toyota dealer and the guy that does most of the work on it reckons the same filter last dilemma a suppose there isn’t a wrong or right
 Share
