Milo500 Posted October 10, 2017 Share Posted October 10, 2017 Hi guys, So I have the most annoying problem I have ever encountered with a car...and if anyone can help with ideas/solutions, I will be extremely happy. So it started a couple of months ago, whereby the the car would run as normal until turned off, and started again when warm. It would then run on 5 cylinders. I found out that it was the injector connectors, and have re wired all 6 of them. Since then nothing changed, and have found out that the no.3 cylinder connector requires pushing down when restarted and then begins running on all 6 again. I thought that it could just be a loose or dodgey connector, so re wired another new one in...nothing changed. This is the current situation, whereby I am having to pushing/wiggle around the no.3 connector until it runs on all 6 after being run and turned off (then re started once warm). Any help will be very appreciated as this is driving me absaloutly mad. The car has a stock side feed rail with 800cc sard injectors Thanks, Tom Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 11, 2017 Share Posted October 11, 2017 Swap number 3 injector to another position, see if the issue follows the moved injector or stays with number three wiring. Quote Link to comment Share on other sites More sharing options...
