Left rear indicator not working??
GTR Fever
 Share
Hello everyone,
Took my Supra for a spin and noticed that the left rear indicator is not working (blinker/ indicator blinks faster now). So I checked the bulb, it's good. Still changed it and it does not work.
Any ideas?
It's a NA/ TT swap auto supra if that helps in this case.
Cheers.
Broken wire somewhere clearly. Track the wire back throughout the car. Worst case situation you will have to run a new feed to the rear from the front. I've never checked the wiring but that would fix the issue if you can't trace the wiring or find the supply.
 Share
