zaheer0027 Posted February 2, 2017 Share Posted February 2, 2017 good day all I started my nat conversion finally. 8 have a question about the iat sensor....where do I put it? on an na it's located just behind the air filter. now that I'm going nat I'm not sure what to do. I've read that you should put it just before the throttle body. also read it's better if it's welded on the actual intake manifold. any help appreciated regards zaheer Link to comment Share on other sites More sharing options...
Josh42 Posted February 2, 2017 Share Posted February 2, 2017 Mine is located behind the air filter, in the intake hose. Link to comment Share on other sites More sharing options...
Swampy442 Posted February 2, 2017 Share Posted February 2, 2017 Its normally in the airbox. Link to comment Share on other sites More sharing options...
