DShox Posted September 20, 2005 Share Posted September 20, 2005 evening all, I need help! Just wondering if anyone else has experienced suspension thud. My Teins are lower on the front than the back and yet the noise is emerging from the rears when I go over bumps. I guess I need to raise the suspension with a C-Spanner? Anyone know what size and where I can get one??? Just wondering if anyone else had this problem. I've had it thudding since I imported it so wanna get it sorted now. I dont wanna spend money getting em refurbed when alls I need to do is raise em a lil. Thanks, D Link to comment Share on other sites More sharing options...
black cat Posted September 20, 2005 Share Posted September 20, 2005 i have a klunk from the rear suspension as i go over bumps. have raged the shit out of the car, nothing has gone snap......?????!!!???? tt steve Link to comment Share on other sites More sharing options...
Robert Posted September 20, 2005 Share Posted September 20, 2005 i had a thud when i went over a bump or hump and it was my rear shocks, got them replaced now its fine Link to comment Share on other sites More sharing options...
DShox Posted September 20, 2005 Author Share Posted September 20, 2005 why replace? - could you not just change the springs or raise em to allow more bounce? im a suspension newb tryin' to avoid shelling out yet more £££! Link to comment Share on other sites More sharing options...
Robert Posted September 20, 2005 Share Posted September 20, 2005 when mark at phoenix checked my shocks the drivers side was worn away and when you push down on the rear it made the same thud sound.The noise had nothing to do with the springs Link to comment Share on other sites More sharing options...
Homer Posted September 20, 2005 Share Posted September 20, 2005 why replace? - could you not just change the springs or raise em to allow more bounce? im a suspension newb tryin' to avoid shelling out yet more £££!  When shocks are broken, they are broken, there's no way around that. Just replace them with new ones. The standard yellow Bilsteins are about as good as you can get without shelling out for a custom 'Chris Wilson' type set-up. They're only around £400 for a set of 4. Link to comment Share on other sites More sharing options...
DShox Posted September 20, 2005 Author Share Posted September 20, 2005 thanks chaps - what about fitment - can you do this yourself? possibly get them second hand if poss cos that would save a little more. if my fronts are ok I might just change the rear teins. Link to comment Share on other sites More sharing options...
Robert Posted September 20, 2005 Share Posted September 20, 2005 ive still got the stock uk shocks and i got my local garage to fit them for £48 for the pair, so not bad. Link to comment Share on other sites More sharing options...
Nic Posted September 21, 2005 Share Posted September 21, 2005 PM me if you need a price for new OEM Bilstein dampers and springs. Link to comment Share on other sites More sharing options...
Paul -C- Posted September 21, 2005 Share Posted September 21, 2005 I've got a drivers side thud as well. So far I've replaced the shocks and all the control arms and bushes, but it's still there. Link to comment Share on other sites More sharing options...
DShox Posted September 21, 2005 Author Share Posted September 21, 2005 huh so you did the big heave ho and it didnt work - now whats the plan? Link to comment Share on other sites More sharing options...
Paul -C- Posted September 21, 2005 Share Posted September 21, 2005 huh so you did the big heave ho and it didnt work - now whats the plan? Turn the stereo up louder  It's actually pissing me off. It sounds like the wheel is actually shaking a tiny amount when I'm driving, but when jacked up it's rock solid. There's also a wind-type noise coming from the wheel which I have no idea what it is. Link to comment Share on other sites More sharing options...
DShox Posted September 21, 2005 Author Share Posted September 21, 2005 not the wheel bearing is it. when i jacked up the rears, I noticed that when i got the wheel nuts as tight as possible, I could rock one wheel back and forth yet the other side was holding steady. have you tried doing up the thread nut tighter or considered it might be a bearing? failing that - possible replacement drop links? I guessed and changed the drop links but that didnt work. then I tried the thread nut but that was tight, then thought it might be the bearings but Toyota checked it out and send my suspension springs werent being given enough room to flex...now I'm in limbo! Link to comment Share on other sites More sharing options...
sim Posted September 22, 2005 Share Posted September 22, 2005 i get a thud as well . i put up with it Link to comment Share on other sites More sharing options...
Paul -C- Posted September 22, 2005 Share Posted September 22, 2005 DShox, the wheel doesn't move at all when the car is jacked up, so I don't think it's the wheel bearing. I've also replaced the drop links and anti-roll bar bushes, so it's not them. If you can move one of your wheels when the car is in the air then it sounds like a wheel bearing problem. Link to comment Share on other sites More sharing options...
VIL Posted September 22, 2005 Share Posted September 22, 2005 I had a thud/bump sound also. Go over a hole or speed bump and clunk there it was. At the time I had a HKS SuperDragger fitted that was beaten to **** due to grounding out on speed bumps etc. Under the car it was bent up and only 1/4" off the rear arm of the car.  Got the Dragger changed and hey presto no more bump sounds! So I guess it was hitting the rear arm when jolted. Check you exhaust is clearing your rear arms, especially if its aftermarket! Link to comment Share on other sites More sharing options...
DShox Posted September 22, 2005 Author Share Posted September 22, 2005 yup but according to Toyota it is not the wheel bearing or nut because I asked them specifically to assess the noise. They took everything apart and put it back together again. They say it is the suspension bottoming out. I spoke to Tein this morning. They have asked me to take 1 wheel off the front and rear (shocks are different) and phone them back with: 1. the stamp/reference on the dampers (to determine the type) 2. the stamp/reference on the springs (to determine the type) Apparently many in Japan didnt follow manufacturer instructions and mixed and matched inappropriate dampers with springs - hopefully it is a case of just replacing the current springs with the correct ones. Find a local Tein dealer (or whatever you have on) who can do the fitting for you and help with the assessment. The dealer will then deal with Tein (or whoever on your behalf). Ta, D Link to comment Share on other sites More sharing options...
DShox Posted September 22, 2005 Author Share Posted September 22, 2005 VIL - yup the exhaust is aftermarket and this was the opinion of Bonsai Cars. I took the Soop to a place with a pit who welded the flapping heat shield on firmly and sent me on my way - didnt solve it. Â The exhaust feels like its on tight - could you move your one easily if you shook it on the back? Link to comment Share on other sites More sharing options...
VIL Posted September 22, 2005 Share Posted September 22, 2005 The `Dragger` when you tried to physically move it seemed solid enough. But you have to think of the travelling forces involved, you hit a pot hole or speed bump at 20/30 + MPH and the exhaust is going to move on its hangers. If the clearance between it and the rear arm is narrow then the likelyhood is they will contact. I`m certainly not suggesting this is the answer to your problem but might be worth investigating further. Noisy/thumping rear ends seem to be common place amongst Supra owners for a variety of reasons so its worth exploring all avenues. Link to comment Share on other sites More sharing options...
DShox Posted September 23, 2005 Author Share Posted September 23, 2005 thanks - wish it was the exhaust - gotta be easier to sort than the suspension! im taking it to a tein dealer in Wolverhampton tomorrow who is gonna tell me whether it is height adjustable. Toyota reckon it has been lowered too much but as it is aftermarket gear, they wouldn't touch it Link to comment Share on other sites More sharing options...
