engine management light comes on
Guest Simon_s13
Guest Simon_s13
hi, I was driving the supra and the engine management light comes on after 15 minutes driving, when I turn off the engine and I start it again the light is off but after 15 minutes it is on again, any idea? thanks
If it's code 42, it's likely to be caused by an aftermarket speed converter that's broken, or by a problem on the odometer circuit board. If your speedo is still working, it's unlikely (but not impossible) to be caused by the speed converter.
Guest Simon_s13
I´ve check the codes on my car but it doesn´t recognize any fault because the light is flashing all the time, any idea about thi problem? thanks
Guest Simon_s13
Check your brake fluid level. If this is low, it can trigger a warning light.
the leves is fine, I was looking for the speed converter but I can´t find it, it normally is fitted in the dash cluster but it isn´t there, anyone knows where can be?
Guest Simon_s13
I´ve removed the speed converter( it was on the gearbox loom) and the ligth is still on after 15 minutes. the brake fluid is in the maximun and I´ve checked again the foult codes and the light is flashing all the time at the same speed. can be possible this problem if the car hasn´t cat?
