Guest Simon_s13 Posted July 17, 2016 Share Posted July 17, 2016 hi, I was driving the supra and the engine management light comes on after 15 minutes driving, when I turn off the engine and I start it again the light is off but after 15 minutes it is on again, any idea? thanks Link to comment Share on other sites More sharing options...
The Raven Posted July 17, 2016 Share Posted July 17, 2016 Check error codes Link to comment Share on other sites More sharing options...
stevie_b Posted July 17, 2016 Share Posted July 17, 2016 Probably code 42, the symptoms match. But I'm speculating, so as Raven said, please check the error codes. Link to comment Share on other sites More sharing options...
Guest Simon_s13 Posted July 17, 2016 Share Posted July 17, 2016 thanks guys i will check it tomorrow, can be the problem caused by the speed conversor? Link to comment Share on other sites More sharing options...
stevie_b Posted July 17, 2016 Share Posted July 17, 2016 If it's code 42, it's likely to be caused by an aftermarket speed converter that's broken, or by a problem on the odometer circuit board. If your speedo is still working, it's unlikely (but not impossible) to be caused by the speed converter. Link to comment Share on other sites More sharing options...
Guest Simon_s13 Posted July 19, 2016 Share Posted July 19, 2016 I´ve check the codes on my car but it doesn´t recognize any fault because the light is flashing all the time, any idea about thi problem? thanks Link to comment Share on other sites More sharing options...
stevie_b Posted July 19, 2016 Share Posted July 19, 2016 Check your brake fluid level. If this is low, it can trigger a warning light. Link to comment Share on other sites More sharing options...
Guest Simon_s13 Posted July 19, 2016 Share Posted July 19, 2016 Check your brake fluid level. If this is low, it can trigger a warning light. the leves is fine, I was looking for the speed converter but I can´t find it, it normally is fitted in the dash cluster but it isn´t there, anyone knows where can be? Link to comment Share on other sites More sharing options...
stevie_b Posted July 19, 2016 Share Posted July 19, 2016 Might be near the odometer, or occasionally on top of the gearbox. Link to comment Share on other sites More sharing options...
The Raven Posted July 23, 2016 Share Posted July 23, 2016 This does it make sence the ecu should have stored a fault. Link to comment Share on other sites More sharing options...
Guest Simon_s13 Posted July 24, 2016 Share Posted July 24, 2016 I´ve removed the speed converter( it was on the gearbox loom) and the ligth is still on after 15 minutes. the brake fluid is in the maximun and I´ve checked again the foult codes and the light is flashing all the time at the same speed. can be possible this problem if the car hasn´t cat? Link to comment Share on other sites More sharing options...
