ben_harmer32 Posted July 10, 2016 Share Posted July 10, 2016 My car has a flashing OD light. Speedo was all working and reading in MPH. Thought it might be the convertor so removed that and it reads fine in KPH but OD light is still flashing. Have checked error codes and have the usual code 42. Any ideas what else I could try please? Car also has optional extra cruise control which I haven't used at all yet due to flashing light. Link to comment Share on other sites More sharing options...
ben_harmer32 Posted July 10, 2016 Author Share Posted July 10, 2016 (edited) http://www.mkivsupra.net/vbb/showthread.php?57157-code-42-no-1-speed-sensor-problem&highlight=o/d Followed the above guide. Not mine but a picture of what I did essentially: Edited July 18, 2016 by ben_harmer32 (see edit history) Link to comment Share on other sites More sharing options...
ben_harmer32 Posted July 11, 2016 Author Share Posted July 11, 2016 Anybody have any idea's please? Link to comment Share on other sites More sharing options...
and1c Posted July 11, 2016 Share Posted July 11, 2016 Does od still work? As in so you have a 4th gear? Link to comment Share on other sites More sharing options...
ben_harmer32 Posted July 11, 2016 Author Share Posted July 11, 2016 (edited) When I press the button on the shifter I can hear it changing between 3rd and 4th, but after doing the wiring mod yesterday I now have no OD light on the dash at all. Edited July 11, 2016 by ben_harmer32 (see edit history) Link to comment Share on other sites More sharing options...
Ric Posted July 11, 2016 Share Posted July 11, 2016 usually the speed sensor in the gear box. or the plastic gear tooth on the sensor has failed. they arent expensive for the toothed part, sensor isnt that cheap. Link to comment Share on other sites More sharing options...
ben_harmer32 Posted July 11, 2016 Author Share Posted July 11, 2016 usually the speed sensor in the gear box. or the plastic gear tooth on the sensor has failed. they arent expensive for the toothed part, sensor isnt that cheap. If this was the case wouldn't the speedo not work? Link to comment Share on other sites More sharing options...
Ric Posted July 11, 2016 Share Posted July 11, 2016 (edited) If this was the case wouldn't the speedo not work? Theres 2 sensors AFAIK, one for the ecu and box, one for the speedo/rev counter Edit - Error 42 relates to speed sensor 1 Edited July 11, 2016 by Ric (see edit history) Link to comment Share on other sites More sharing options...
ben_harmer32 Posted July 18, 2016 Author Share Posted July 18, 2016 Ok, got a new converter. Wired it to the back of the Speedo and odometer as per instructions. Everything is working but after nearly 2 hours the light has just started flashing again. I took out the above mentioned wiring mod as the converter used those wires. Is it worth removing the converter from the odometer (leaving the Speedo bits) and doing the above wiring mod again? Will this make it read in KM even though the Speedo is in MPH?? Link to comment Share on other sites More sharing options...
Konrad Posted July 18, 2016 Share Posted July 18, 2016 Normally it starts flashing when readout from speedo/odometer line is not same as one ECU is getting from same sensor. Most people nailed it down to odometer buffer, in your case it is easy to bypass odometer and feed wire directly from speed converter to ECU to heal a problem. Link to comment Share on other sites More sharing options...
