salaar Posted May 29, 2016 Share Posted May 29, 2016 My idle use to be around 700, but I just took it for a test and it sits around 200! I was scared it would cut out so kept firm on the clutch but once back on my drive, I let it run and it was fine. Is 200 okay or too low? Link to comment Share on other sites More sharing options...
SPG Posted May 29, 2016 Share Posted May 29, 2016 Are you sure its not reading 600rpm? Link to comment Share on other sites More sharing options...
salaar Posted May 29, 2016 Author Share Posted May 29, 2016 Its the second line up from 0, TRD tach Link to comment Share on other sites More sharing options...
JackyBoi Posted May 29, 2016 Share Posted May 29, 2016 Its the second line up from 0, TRD tach Looking at the tacho the second line is 400rpm, 1st line 200rpm and then obviously 0. Not sure if that's a good or bad idle haha Link to comment Share on other sites More sharing options...
salaar Posted May 29, 2016 Author Share Posted May 29, 2016 Intake is vibrating a bit more (na) Link to comment Share on other sites More sharing options...
mellonman Posted May 29, 2016 Share Posted May 29, 2016 I expect its down to the stock ecu learning the new fuel trims it "should" sort its self after a long drive Link to comment Share on other sites More sharing options...
