Lower Wishbone camber Adjusters just spinning
G9RGE
I took the supra to a friends garage yesterday to get the 4 wheel alignment sorted. He has done my other Supras so I have never had any issues with him or his garage.
They were unable to adjust the passenger side front and rear camber as the bolt was just spinning and not moving the wishbone.
So my questions:
Am I right in thinking that the bush is Knackered ( is it worth replacing for polybushes)
Do I need new lower arms and if so where is the best place to get them?
Thanks
I don't see how if the eccentric adjuster rotates it doesn't move the arm, unless the rubber bush in the arm is totally shot
Does it have the correct adjusters fitted with eccentric washers on each end ?
- - - Updated - - -
Can you get a photo of the adjusters ?
