Help Identifying Boot Seal
C12MMO
Evening all, while cleaning my car at the weekend I noticed an ingress of water into the boot area, after further inspection it looks like the rubber boot surround has perished and let water in.
Picture below
Would I be right in thinking that the correct part is 67881A as per the below image?
Thanks Karl
I had the same problem and it turned out not to be the rubber seal, it was actually a couple of the weld seems on the body letting the water in... Seems to be a common problem.... Some clear silicone sorted my problem out...
I will look into this also then. Thanks for the heads up.
