Al Massey Posted November 10, 2015 Share Posted November 10, 2015 I used to use 1 of these systems and found it to be pretty good, some people found that the sensors took too long to pick up a signal but mine worked well, http://www.tyresave.co.uk/smartire.html I've seen these before and been after one for ages Just forgot what it was called Thank you sir Link to comment Share on other sites More sharing options...
inazone Posted November 10, 2015 Share Posted November 10, 2015 I use this one. Have been really pleased with it. Would recommend fitting solid valve stems so that you can lock the sensors in place. http://www.tyredog.com.au/store/4-wheel-wtpms/4-wheel-tyre-pressure-monitor-0-to-60-psi.html Link to comment Share on other sites More sharing options...
Wez Posted November 11, 2015 Share Posted November 11, 2015 I used to use 1 of these systems and found it to be pretty good, some people found that the sensors took too long to pick up a signal but mine worked well, http://www.tyresave.co.uk/smartire.html I also have one of these, we had a group buy a few years back Link to comment Share on other sites More sharing options...
Wez Posted November 11, 2015 Share Posted November 11, 2015 I use this one. Have been really pleased with it. Would recommend fitting solid valve stems so that you can lock the sensors in place. http://www.tyredog.com.au/store/4-wheel-wtpms/4-wheel-tyre-pressure-monitor-0-to-60-psi.html I wonder how these measure temp when the body of the sensor is travelling quickly through air external to the wheel as it rotates. What sort of temp readings do you get? Link to comment Share on other sites More sharing options...
pedrosixfour Posted November 11, 2015 Author Share Posted November 11, 2015 I wonder how these measure temp when the body of the sensor is travelling quickly through air external to the wheel as it rotates. What sort of temp readings do you get? And do you need to remove the sensor from the valve to inflate/deflate a tyre? If that's the case I think the internal sensor arrangement trumps it. Link to comment Share on other sites More sharing options...
pedrosixfour Posted November 11, 2015 Author Share Posted November 11, 2015 I also have one of these, we had a group buy a few years back I know you'd be all on for taking the tyre monitoring aspect to the next level with the CAN feature, but how would you rate the Tyresure system for use on track? Link to comment Share on other sites More sharing options...
Wez Posted November 11, 2015 Share Posted November 11, 2015 I know you'd be all on for taking the tyre monitoring aspect to the next level with the CAN feature, but how would you rate the Tyresure system for use on track? It was good, worked well enough for me. I got a local tire shop to fit all the sensors and then wired in a perm power feed and fixed the unit to the dash Link to comment Share on other sites More sharing options...
inazone Posted November 12, 2015 Share Posted November 12, 2015 I wonder how these measure temp when the body of the sensor is travelling quickly through air external to the wheel as it rotates. What sort of temp readings do you get? Yes I have wondered how it measures the temperature, might be something to do with centrifugal force, warm air molecules pushed towards the sensors? Never really checked temperature tbh, only interested in the pressure. Link to comment Share on other sites More sharing options...
Tsia Posted November 12, 2015 Share Posted November 12, 2015 Shame the set that I got is with the garage waiting to be fitted at the minute. I found a system that has a small screen (1.5 inch or so I'd say) that you install anywhere you like. It's got pressure, rapid deflation sensor and high temp sensors and cost around £150. Looks like this: Bit difficult to get hold of at the moment though. Link to comment Share on other sites More sharing options...
pedrosixfour Posted November 12, 2015 Author Share Posted November 12, 2015 Shame the set that I got is with the garage waiting to be fitted at the minute. I found a system that has a small screen (1.5 inch or so I'd say) that you install anywhere you like. ..... Bit difficult to get hold of at the moment though. That appears to be the same system that Nic directed us to on the IMOC group buy. Link to comment Share on other sites More sharing options...
pedrosixfour Posted February 12, 2016 Author Share Posted February 12, 2016 Well with my new tyres on the way, and my new rims waiting patiently to receive them there wasn't much left to do other than order a TPMS. So I just bought a kit from the crowd that Bignum linked to, seeing as it is the same kit that was bought in the group buy and there seems to be no problems with it. £189 for the kit. £20 postage to Ireland. The joys of "island" living! Link to comment Share on other sites More sharing options...
