krisgowing Posted October 20, 2015 Share Posted October 20, 2015 Gonna be totally honest here I have no idea how rims fits ie the size and what you need to look out for. My current 19inch alloys are chrome which has tarnished and look's well.. terrible. I've been looking at another pair or alloys just while I save up for a brand new pair. As my tyres are getting low I'll be getting some new ones ready for winter. I've looked at these just for a little while as I used to have some similar on my old car https://www.gumtree.com/p/wheel-rims-tyres/4x-bmw-alloy-wheels-/1138557435 But what do I need to look at when looking at rims for the Supra. Appreciate any help and I'm probably being very dimwitted but I'm a rookie when it comes to this! Link to comment Share on other sites More sharing options...
mattdavies Posted October 20, 2015 Share Posted October 20, 2015 They are BMW fitment ( 5x120 ) you need 'Jap' fitment which is 5x114.3 Link to comment Share on other sites More sharing options...
Dnk Posted October 20, 2015 Share Posted October 20, 2015 The measurement where the holes are that the wheel nuts fit is called the PCD and on a mkiv is 5 x 114.3, this has to be correct The Spigot bore is 60.1 mm on a mkiv, this is the hole on the inside of the wheel which should fit on the spigot hub, it is best to be this size but can be bigger and then you use spigot rings. The BMW wheels have the wrong PCD so wont fit as they are 5 x 120 Link to comment Share on other sites More sharing options...
Dnk Posted October 20, 2015 Share Posted October 20, 2015 The measurement where the holes are that the wheel nuts fit is called the PCD and on a mkiv is 5 x 114.3, this has to be correct The Spigot bore is 60.1 mm on a mkiv, this is the hole on the inside of the wheel which should fit on the spigot hub, it is best to be this size but can be bigger and then you use spigot rings. Stock 17" wheels are 17x 8 front and 17 x 9.5 rear and both have a 50 offset http://www.willtheyfit.com is useful tool to check when changing wheels and you can compare to stock or whatever you have fitted now The BMW wheels have the wrong PCD so wont fit as they are 5 x 120 Link to comment Share on other sites More sharing options...
krisgowing Posted October 20, 2015 Author Share Posted October 20, 2015 Thanks guys. Appreciate the help on this one. Will look for some 5x114.3 then Link to comment Share on other sites More sharing options...
SupraP-Z Posted October 20, 2015 Share Posted October 20, 2015 You can buy adaptors which allow other PCD's to fit onto the supra, but id just buy the right fitment in the first place Link to comment Share on other sites More sharing options...
