James Posted August 13, 2015 Share Posted August 13, 2015 Looking at possibly going 18x12 ET44 on my next set of wheels. Need to do some careful measuring to make sure it'd fit, but thought I'd also ask if anyone was running similar already? Any pictures if so? I'm 18x11.5 ET50 at present, so would be essentially just adding an extra 1/2" to the lip, with inside clearance remaining the same. Tyre size is currently 315/30/18 and would be staying that way. Thanks in advance Link to comment Share on other sites More sharing options...
mattdavies Posted August 13, 2015 Share Posted August 13, 2015 (edited) Any pics of current clearance ? I would estimate that you should be alright. I run a 10" et20 rear and your proposed set up is only 1.4mm more poke, i can run a 265/35 without too much issue, so going that every half inch and 10mm more width on a tyre keeps roughly the same 'stretch' then that would mean: 10" - 265 10.5" - 275 11" - 285 11.5" - 295 12" - 305 this is fag packet maths Edited August 13, 2015 by mattdavies (see edit history) Link to comment Share on other sites More sharing options...
James Posted August 13, 2015 Author Share Posted August 13, 2015 Any pics of current clearance ? I would estimate that you should be alright. I run a 10" et20 rear and your proposed set up is only 1.4mm more poke, i can run a 265/35 without too much issue, so going that every half inch and 10mm more width on a tyre keeps roughly the same 'stretch' then that would mean: 10" - 265 10.5" - 275 11" - 285 11.5" - 295 12" - 305 this is fag packet maths Cheers Matt. Giving me tyre size maths is redundant right enough That has already been decided based on my existing arrangement and they're fine in that sense. I'm solely looking at where the wheel is going to sit relative to the arch, given that it is flared. I was just curious as to whether anyone else has run that sort of size on a stock arch with a similarly big tyre. I know the inner clearance will be alright. It's just the outside. I really just need to measure it and go from there For reference, my mate Marc (AB10 on here) is 11" ET17 at the rear, but runs a 265 and camber to clear the arch. I don't want to reduce my tyre size down like that though. I'd be keeping 315/30 anyway. I'll stay 11.5" and perhaps be more conservative at ET43 should I not go 12" As far as current clearance: Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 13, 2015 Share Posted August 13, 2015 (edited) Should be ok Edited August 13, 2015 by pedrosixfour (see edit history) Link to comment Share on other sites More sharing options...
James Posted August 13, 2015 Author Share Posted August 13, 2015 Should be ok http://www.mkivsupra.net/vbb/attachment.php?attachmentid=204069&d=1439474584 Oh I've already been through this All I need to do is make sure that the 12.4mm extra will be in the right place Link to comment Share on other sites More sharing options...
Zeiretto Posted August 14, 2015 Share Posted August 14, 2015 Should be ok http://www.mkivsupra.net/vbb/attachment.php?attachmentid=204069&d=1439474584 Where can I calculate this? Link to comment Share on other sites More sharing options...
mattdavies Posted August 14, 2015 Share Posted August 14, 2015 Where can I calculate this? http://www.Wiltheyfit.com James, I would suspect that with the inside of the tyre being in the same place then the tyre will move outwards from that point, so I believe the tyre walls will begin to 'stretch' and the tyre tread will move with it, I dont think the thread will move tthe full 12mm maybe only half so 6mm, meaning the top of the tyre will be 6mm closer to the arch. I know you are looking for someone with experience, I am just trying to help. Speak to Jazz as he runs a 12" rear wheel. Link to comment Share on other sites More sharing options...
James Posted August 14, 2015 Author Share Posted August 14, 2015 http://www.Wiltheyfit.com James, I would suspect that with the inside of the tyre being in the same place then the tyre will move outwards from that point, so I believe the tyre walls will begin to 'stretch' and the tyre tread will move with it, I dont think the thread will move tthe full 12mm maybe only half so 6mm, meaning the top of the tyre will be 6mm closer to the arch. I know you are looking for someone with experience, I am just trying to help. Speak to Jazz as he runs a 12" rear wheel. Absolutely Matt - I appreciate the postings also Precisely that - I am not certain by how much the tread will move, that is the factor I can't confirm having not put a 315/30 onto a 12" rim before compared with how it sits on the 11.5". I think that I've made my mind up. As I have quite an aggressive roll & flare on the arch, I'm going to brave it and go 18x12 ET44 with the 315/30. Now for the fronts (aiming for 18x10 ET36 285/30 there). (And the expense, of course!) Link to comment Share on other sites More sharing options...
mattdavies Posted August 14, 2015 Share Posted August 14, 2015 Now for the fronts (aiming for 18x10 ET36 285/30 there). (And the expense, of course!) Do you have the tyres already for the front ? I would probably run a 265/35 I run a 225/40 on a 10" front ET20 Link to comment Share on other sites More sharing options...
James Posted August 14, 2015 Author Share Posted August 14, 2015 Do you have the tyres already for the front ? I would probably run a 265/35 I run a 225/40 on a 10" front ET20 Yep I'm currently 285/30 on 18x10 at ET41. Link to comment Share on other sites More sharing options...
mattdavies Posted August 14, 2015 Share Posted August 14, 2015 Yep I'm currently 285/30 on 18x10 at ET41. Oh ok, so you are putting a 5mm spacer on ? Link to comment Share on other sites More sharing options...
James Posted August 14, 2015 Author Share Posted August 14, 2015 Oh ok, so you are putting a 5mm spacer on ? No no - I'm buying a new set of wheels It just so happens that my existing wheels aren't too far off in sizes, so I'm working round that to spec them. Link to comment Share on other sites More sharing options...
JackyBoi Posted August 14, 2015 Share Posted August 14, 2015 Don't know if this helps at all, but I'm running a 19x10.5 et30 with a 305/30 tyre and the rear arches only needed rolling out a tiny bit. With a 35 profile tyre they would need rolling slightly more, but figment is surprisingly good. Link to comment Share on other sites More sharing options...
