Big Mark Posted May 24, 2015 Share Posted May 24, 2015 I've got noise coming from the throttle body area when I turn my ignition off. Probably from where I removed it to paint it. Sounds like something needs adjusting but not sure what or how. Noise is 4 seconds into the video link below (fingers crossed it works as has issues uploading it) https://www.youtube.com/watch?v=1z-Jct568mA&feature=youtu.be Link to comment Share on other sites More sharing options...
Big Mark Posted May 24, 2015 Author Share Posted May 24, 2015 Anyone???? Link to comment Share on other sites More sharing options...
supra matt Posted May 24, 2015 Share Posted May 24, 2015 Sounds like it's coming from the track control motor mate, pop off the intercooler pipe and see if you can move the flap by hand, Link to comment Share on other sites More sharing options...
Swampy442 Posted May 24, 2015 Share Posted May 24, 2015 Yeah as above probably the sub throttle/TRAC actuator Link to comment Share on other sites More sharing options...
Big Mark Posted May 24, 2015 Author Share Posted May 24, 2015 Thanks guys. So assuming that is the isse how do I fix it? Guessing I put something back on wrongly when I took it off to paint. Link to comment Share on other sites More sharing options...
supra matt Posted May 24, 2015 Share Posted May 24, 2015 Thanks guys. So assuming that is the isse how do I fix it? Guessing I put something back on wrongly when I took it off to paint. Did you strip the throttle body down for paint mate? Sounds like it dosent no where its stop is and its trying to move, Link to comment Share on other sites More sharing options...
Big Mark Posted May 24, 2015 Author Share Posted May 24, 2015 I took off the sensors (held on by the 2 small screws) but the rest of the parts I just masked off. Link to comment Share on other sites More sharing options...
supra matt Posted May 24, 2015 Share Posted May 24, 2015 There will be you problem right there mate you will need to set them back up there the throttle position sensors, not to be touched really lol, Link to comment Share on other sites More sharing options...
supra matt Posted May 24, 2015 Share Posted May 24, 2015 Link to comment Share on other sites More sharing options...
Big Mark Posted May 25, 2015 Author Share Posted May 25, 2015 Thanks mate. I'll get the multi-meter out and give it a go. Link to comment Share on other sites More sharing options...
Big Mark Posted May 25, 2015 Author Share Posted May 25, 2015 http://images.tapatalk-cdn.com/15/05/24/ab7066648d5e16c169802df64af2439f.jpg http://images.tapatalk-cdn.com/15/05/24/ce0f428cbe07934391a4d3b7aade9873.jpg Which of the repair manuals are these taken from? I can't see an EG manual here: http://www.mkivsupra.net/vbb/content.php?51-Repair-Manuals Link to comment Share on other sites More sharing options...
supra matt Posted May 25, 2015 Share Posted May 25, 2015 Should be in the efi manual mate Link to comment Share on other sites More sharing options...
berg Posted May 25, 2015 Share Posted May 25, 2015 Any lights flashing on the dash like o/d or slip control? Link to comment Share on other sites More sharing options...
supra matt Posted May 25, 2015 Share Posted May 25, 2015 Are you on android mate? If you are go to the the app store and type kdh services in Link to comment Share on other sites More sharing options...
Big Mark Posted May 25, 2015 Author Share Posted May 25, 2015 No lights on the dash at all and car drives great, if anything it drives better now that it did before I did the work. Not for android, don't do smart phones, Nokia with buttons all the way. Just looked at EFI manual, not in it. Link to comment Share on other sites More sharing options...
supra matt Posted May 25, 2015 Share Posted May 25, 2015 (edited) What eles do you wont to know? Or can you not see my pics clearly, Just looked though the club manual there not the full set and don't have the section on it, Edited May 25, 2015 by supra matt (see edit history) Link to comment Share on other sites More sharing options...
Big Mark Posted May 26, 2015 Author Share Posted May 26, 2015 I wanted to be able to print off each page so that I could have them to hand when doing the work. But it's ok. I found the pdf here: http://www.shoarmateam.nl/upload/MKIVSupra/Supra-MKIV-Repair-Manual/Engines/SFI%20System%20-%202JZ-GTE.pdf Thanks for your help. - - - Updated - - - I wanted to be able to print off each page so that I could have them to hand when doing the work. But it's ok. I found the pdf here: http://www.shoarmateam.nl/upload/MKIVSupra/Supra-MKIV-Repair-Manual/Engines/SFI%20System%20-%202JZ-GTE.pdf Thanks for your help. Link to comment Share on other sites More sharing options...
supra matt Posted May 26, 2015 Share Posted May 26, 2015 No problem mark hope you get it sorted, Link to comment Share on other sites More sharing options...
