Gte rocker covers on ge head
Guest will_1223
Guest will_1223
Good evening all, I'm embarking on a mission, I will be having a 2jz na-t built which will have a gte style Inlet plenum on it but for it looking a bit neater I wondered if the gte non vvti rocker covers will fit on a ge non vvti head, many thanks in advance
Im sure they do FOSTA on here did this on his na-T build if you search for his build thread im sure he did a walk through
Guest will_1223
Awesome, think they just neaten things up, can I use a gte coil pack cover even with leads on?
